My first build..suggestions, comments, help?-->800$ multipurpose PC
Hey everyone,
Ive been debating building my own desktop for the past several months and about 3 weeks ago I deceided to start down the road to selecting the various components in order to successfully and hopefully build my own PC. This pc will be used for a variety of tasks including gaming, watching/recording tv (USB tv tuner), burning DVD's, and running intensive apps such as solidworks and autocad. Below is my current build that ive come up with. Since i am very new to this I am very open to any and all comments. I am mainly wanting to verify that each of these components are compatible with one another and any other suggestions that I should know about before purchasing the parts!
NOTE: I have two builds that I am currently contemplating. The first one I came up with on my own and the second one was recommended to me by a friend. Both are open to any changes that anyone suggests. Which one do you think I should go with?
APPROXIMATE PURCHASE DATE: 2-4 weeks
BUDGET RANGE: 800$ US
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Multitasking, gaming, CAD, Burning DVD's
PARTS NOT REQUIRED: Keyboard, Mouse, Monitor, Speakers, OS
PREFERRED WEBSITE(S) FOR PARTS: newegg.com, but I am available to buy from the cheapest vendor out there!
PARTS PREFERENCES: Does not Matter
OVERCLOCKING: Probably not
MONITOR RESOLUTION: 1680x1050
BUILD NUMBER 1:
MOTHERBOARD:
MSI P45 Neo3-FR Intel P45 Core 2 Extreme/Core 2 Duo/Core 2 Quad Socket 775 1600 MHz PC2-8500 DDR2-1066 ATX Motherboard (98.99$)
http://www.amazon.com/MSI-Neo3-FR-PC2-8500-DDR2-1066-Motherboard/dp/B001B8KE5G
CPU:
Intel Core 2 Duo E8500 Wolfdale 3.16GHz 6MB L2 Cache LGA 775 65W Dual-Core Processor (189.99$)
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115036
GRAPHICS CARD
SAPPHIRE 100259-1GL Radeon HD 4870 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card (199.99$)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102801
PSU
CORSAIR CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply(74.49$)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
HARDDRIVE
Western Digital Caviar SE16 WD2500AAKS 250GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive (54.99$)
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136161
RAM
Patriot Viper 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory (33.99$)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820220335
DVD-DRIVE
SAMSUNG Black 22X DVD+R 8X DVD+RW 16X DVD+R DL 22X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 22X DVD Burner (24.99$)
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151171&Tpk=Samsung%20SH-S223F
CASE
Antec Three Hundred Black Steel ATX Mid Tower Computer Case (58.99$)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042&Tpk=Antec%20Three%20Hundred
TOTAL COST: 736.92$
BUILD NUMBER 2:
COOLER MASTER RC-690-KKN1-GP Black SECC/ ABS ATX Mid Tower Computer Case $75
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119137
ASUS M4A78T-E AM3 AMD 790GX HDMI ATX AMD Motherboard $140
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131366
MSI N260GTX-T2D896-OCv4 GeForce GTX 260 896MB 448-bit DDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card $165 ($145 after MIR)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127430
PC Power & Cooling Silencer PPCS500 500W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Power Supply $70 ($60 after MIR)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817703015
AMD Phenom II X4 810 2.6GHz 4 x 512KB L2 Cache 4MB L3 Cache Socket AM3 95W Quad-Core Processor $170
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103650
OCZ Platinum 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel Kit Desktop Memory $64
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227297
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive $75
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136319
LG Black 22X DVD Burner $24
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136152
TOTAL = $782.92 - Rebates + S&H
Like I said earlier..i am quite new to this and want to hopefully have a successful and positive build that will give me a desktop that will last for some time. i am open to all suggestions and comments.
thanks,
Austin
4 answers Last reply
More about build suggestions comments help multipurpose
  1. I like the second build better, but I would tweak it up a little:
    Antec Three Hundred Black Steel ATX Mid Tower Computer Case - Retail
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042&Tpk=Antec%20Three%20Hundred $58.95
    CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply - Retail
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006&Tpk=750tx $109.99 - $10.00 MIR (This PSU has enough power to run a second GPU in crossfire if needed in the future).
    AMD Phenom II X4 940 Deneb 3.0GHz 4 x 512KB L2 Cache 6MB L3 Cache Socket AM2+ 125W Quad-Core Black Edition Processor - Retail
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819103471 $189.99
    GIGABYTE GA-MA790X-UD4P AM3/AM2+/AM2 AMD 790X ATX AMD Motherboard - Retail
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813128387 $109.99
    G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory - Retail
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820231166 $54.99
    SAPPHIRE 100259-1GL Radeon HD 4870 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814102801 $189.99 - $15.00 MIR (I would get an ATI GPU so you have the option of crossfire in the future)
    WESTERN DIGITAL WD3200AAKS 320GB SATA 7200 RPM 16MB Hard Drive Bulk
    http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=10005615&prodlist=celebros $51.99
    LG 22X DVD±R DVD Burner Black SATA Model GH22NS30 - OEM
    http://www.newegg.com/Product/Product.aspx?Item=N82E16827136152 $23.99
    Total - $789.88 - $25.00 MIR's
  2. Here are my recommendations to update in Build #1: (Keep all other items the same...)
    MOBO: GIGABYTE GA-EP45-UD3P LGA 775 Intel P45 ATX Intel Motherboard ($134.99 [114.94 after MIR])
    Case: COOLER MASTER RC-690-KKN1-GP Black SECC/ ABS ATX Mid Tower Computer Case ($69.99)
    HDD: Western Digital Caviar Black WD6401AALS 640GB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive ($74.99)
    Total Cost = $803.42 - Rebates + S&H
    Here are my recommendations to update in Build #2: (Keep all other items the same...)
    GPU: SAPPHIRE 100259-1GL Radeon HD 4870 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card ($199.99)... Going to the 4870 will allow you to setup Crossfire down the road when you have more money
    PSU: CORSAIR CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply ($74.49)
    CPU: AMD Phenom II X3 720 2.8GHz Socket AM3 95W Triple-Core Black Processor Model HDZ720WFGIBOX ($139.00)... Phenom II X3 720 BE is a better CPU than the AMD Phenom II X4 810 due to the OC'ing abilities... IMO.
    Total Cost = $791.48 - Rebates + S&H
    Either option will be a very good system for your requirements. IMO... you'll be better served with the E8500 due to the higher clock speed.
  3. I have to disagree and say the quad core would be better since the OP said he will be using Solidworks and AutoCAD.
  4. +1 shortstuff_mt...
    I was looking at it as more of a Gaming System over the Multitasking requirements involving Solidworks and AutoCAD. The Quad core would be better for the multitasking and the E8500 would be better for gaming... IMO
Build Systems Product
