im about to build a new system but im not sure which corsair psu to choose between 620w, 750w or 850w but most likely, this will be the parts for now and i'll be completing all the fans of the antec 902 case while planning to sli my gpu in the near future..
cpu intel i7-920, 2.66ghz
mobo asus P6T DELUXE
gpu GTX 260 sp 216
DDR3 Corsair dominator ,TR3X6G1600C8D,88820
hd 500gig SEAGATE 16MBcache ST3500418AS
dvdRW samsung sh-s223
CASE ANTEC 902
LCD SAMSUNG 23" (P2370G)
will a 620w psu work? or do i need more than that to supply the 2 gpu in the future considering a lot of fans installed in the antec case?
thanks!
Message edited by jisheria on 09-04-2009 at 06:26:45 PM
------------------------------If you like my answer, select me as the best answer.
"Two things are infinite: the universe and human stupidity; and I'm not sure about the universe.". Albert Einstein.
Reply to saint19
i would get the corsair 750tX, it may be a bit more than what you need, though it would have enough pci-e connectors 9so no adapters), plus its only $100 @ newegg.com
If you are going SLI your video cards, you will be using most of the cables on a TX750. And if you are going to be using most of the cables, modular is a waste of money.
ouch! im sorry i wasnt able to catch up^^ what do you mean by modular is a waste of money?
i guess what i wanna make sure of is that corsair hx series 750w psu can sli two power hungry gtx 275 efficiently^^
thats what i trully worrying for right now, i dont wanna end up purchasing a bomb that will blow up my system Y_Y
An HX750 is the modular version of the TX750. It would work fine. But, as jsc said, if your going to SLI 2 GTX260's, you'll be using most of the cables, so paying extra for the modular isn't worth it.
Yes, easily. Corsairs are very conservatively designed. One of the tech sites tested the TX750. They were able to pull more than 900 watts out of before it electronically shut down. Most PSU makers would call it a 900 watt PSU.
