The two main differences of the Gigabyte board are the crossfire ability and overclocking. You'll get no crossfire and lesser overclock with the 770 board.
In terms of quality, the PC Power & Cooling Silencer would be better than the OCZ but OCZ is a modular PSU
If you are not much fixed to Modular PSU, then get the PC Power Cooling...
Reason - You can get one more 4850 in crossfire for just $35 more than your previous setup with that 4870 1GB
And for 1080p resolution, the 4850 crossfire would be very powerful...
And those PSUs can handle 4850 in crossfire...
So what do you think ?
Message edited by gkay09 on 06-02-2009 at 08:31:08 AM
Get this Graphics card by today if you can as it has a very good offer...
SAPPHIRE 100269OCSR Radeon HD 4890 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - OC edition - Retail
$20 off with promo code HARDOCP61VGA2, ends 6/8
http://www.newegg.com/Product/Prod [...] 6814102831
It is factory overclocked to 1GHz and is cheaper than the standard one...This is a very good deal...$20 off with the code too...but valid only today...
200 for the card is a great price, Im reading the reviews of the card, many people is having problems with the "fan" and the extra noises. Dunno but this card is like 50 USD more cheaper than the others "normal" 4890 cards, little weird.
I just checked out the reviews...And I feel that mostly all the ATI cards have this fan noise problem...And that too this card comes overclocked @ 901MHz and now 1GHz(Which I had mistaken) so the stock fans have to do more work, hence give out more noise...
Apart from the noise issue, I dint see any major problems that those people encountered...
For your doubt about the cost, it might be because of the newegg's pricing algorithm, which I heard automatically reduces the prices if demand goes down...
The OC version was priced lot higher, so people were not opting for it, which led to low demand and hence the above...though check the reviews of that card in the net...
Those 2 are better than the OCZ ModXStream Pro OCZ500MXSP 500W ??
because is 10 more USD
What about the black caviar, they are 75 USD for a 640 gb, and my primary option was the 16mb cache 320gb, doesnt matter the size of the HD for me, already have 2 TB in external drives, so i need one for the OS and thats it.
Really worth the extra 20 usd for the 16mb plus cache?
