Hi, I have a 2600k and a Noctua NH-D14 in my HAF 932 case. Heating isn't the issue, voltage is. Here's the thing: I set my CPU voltage in the BIOS as 1.480 volts in order to achieve stability at 4.8GHz, but I then boot into windows, and CPU-Z says my core voltage is between 1.360 and 1.378. Which voltage is the accurate one? Also, will keeping the voltage and clocks at these levels kill my processor if i run the clocks 24/7, even with my D14 cooling it?
BTW, I have an ASUS sabertooth p67 motherboard
