Memory speed only 800mhz?
conbutts
35
Hi, I purchased a pc with 6gigs of ram at 1600mhz. However, when I run a benchmarking test it tells me that I have 3 sticks of 2048 mgs at only 800mhz! Can someone explain why this is. Am I missing something? Can i change the speed manuallY?
thanks
Lee-m
866
it would help if you told us your exact computer spec. Some setups only alow 800mhz maximum.
However changing bios settings, and as in my case, overclocking help get my ram upto its stock speeds.
conbutts
35
Hey Lee, sorry.
My specs:
i7 Processor i7-920 (2.66GHz)
6GB CORSAIR XMS3 TRI-DDR3 1600MHz
ASUS® P6T DELUXE V2
Windows 7 Home Premium 64 Bit
1GB ATI RADEON™ HD 5870
600W Quiet Quad Rail PSU
COOLIT DOMINO A.L.C. CPU LIQUID COOLER
Lee-m
866
I dont have an i7 myself (yet), so others will be more helpful than my self.
But your rig is more than capable of running at the required speeds.
I asume its as easy as going into the bios and setting your ram speed.
As for the missing ram, I asume thats down to two of the sticks not being installed correctly. They have to be installed in tripple channel config. usualy these are shown as coloured dimm slots on the board.
If you check ur bios or download cpu-z, it will shed some light on the problem im sure. At the very least it will show you what sticks of ram it is seeing, and in which slots.
conbutts
35
Thanks Lee but Im not actually missing any ram. You mis-read my post. I am going to go into my bios and try and adjust the speed.
cheers
Lee-m
866
Yeah, I miss read. Apologies.
Let us know how it goes.
Lee-m
866
Id say just check over your settings over again. I dont know enough about LGA 1366 ram configs. Others on here will.
If the ram is rated at 1600, and your board supports that speed... it should work just fine.
rand_79
829
What is the maximum frequency for DDR3 memory when used with Intel® Core™ i7-900 processor series?
These processors support DDR3 memory with a maximum frequency of 1066 MHz. If faster DDR3 memory is used (such as 1333 MHz or 1600 MHz), it will be down-clocked to operate at 1066 MHz.
thats a quote off intel's site.
So to use faster memory you need to overclock the processor.
also quad rail psu's are generally garbage, Thats like talking about 14" steel rims on a car.. something better left unsaid.
