Hey...Sarah is Back!
Best answer from Grem135.
I have windows 7 installed and when i install the driver it gets to the end and hangs.Not sure what the problem is.Hopefully someone can help me out with this.
is it the driver suite or just the standalone? try installing the standalone. if its not working, windows 7 might be corrupt, may have to reformat
If you have ever had an ht omega driver installed then uninstall it and delete the file C:\Windows\SysWOW64\HsMgr.exe download lastest drivers, extract the drivers to a temp folder, then delete the file "HsMgr.exe" now install thx to dornif on windows seven forums for this fix
