Solved
MEMORY PROBLEM?
NO VIDEO ON MONITOR WHILE ASSEMBLING THE SYSTEM ,LOOKED & CHECKED EVERY POSSIBLE DEFECT BUT EVERY THING WAS FINE & INTACT.THEREFORE I COULD NOT INSTALL THE OPERATING SYSTEM.PLEASE TELL WHERE THE PROBLEM OCCURS.BOARD FANS ,BOARD LIGHTS CPU.VGA FAN WORKED NICELY BUT NO ON SCREEN VIDEO
M/B STRIKER II NSE
CPU INTEL CORE 2 QUAD Q9550 2.83
VGA CARD XFX NVIDID GEFORCE 9800GTX+
P/SUPPLY=OCZ MODXSTREAM-PRO 700W
RAM[OCZ TRIPLE CHANNEL PC3 12800 ....8 8 8 @1.65V...(OCZ3X1600V3GK)
SOME ONE TOLD ME THAT IT IS BECAUSE OF WRONG MEMORY ,AS THIS BOARD SUPPORT ONLY DUEL CHANNEL DDR3,AND YOU ARE USING TRIPLE CHANNEL DDR3.
PLEASE HELP ,
qaslam2007@gmail.com
5 answers Last reply Best Answer
More about memory problem
  1. Do you try with another PSU?
    Sir, Which one should i try please write model with brand name so that there will be no more confusion,& also tell me sir is the ram compatible for this board .
    Thanks
  3. Best answer
    oh, try with a RAM dual channel, the brand isn't importan for now, just the speed and the voltage.
    For the PSU is the same, try with some good PSU, like thermaltake, OCZ, corsair, coolermaster... 500W at least.
  4. Thanks a lot .ur advise corrected my problem .Thanks once again
  5. Any time, that's what we're here for.
Asus Motherboards
