Need help choosing fans n heat sink for new build
caesparktom
106
Hi, I'm building a workstation--my first-- and don't know how to choose fan and heat sinks. Would really appreciate it if someone can help me get started. Looking for something quite, and i'm not really an overclocker so no need to get crazy. The case is Corsair 700d and the motherboards is SUPERMICRO X8DAL-i.
Corsair 700d cooling specs:
(x3) 140mm Fans
Up to 4x 120mm Fans (not included)
Does this mean 3 140mm Fans are included and there is space for upto 40 additional 120mm fans??
Here are spec sheets for motherboard & CPU
http://www.supermicro.com/products/motherboard/QPI/5500/X8DAL-i.cfm
http://ark.intel.com/Product.aspx?id=47925
And here is thermal components matrix from supermicro
http://www.supermicro.com/support/resources/Thermal/
Thank you for any help.
cpu-supported heat sinks...narrows it down:
Intel® DP and MP Systems
SNK-P1036P
SNK-P1035P
SNK-P1034P
SNK-P0041
SNK-P0040AP4
SNK-P0038PS
SNK-P0038PS
SNK-P0038P
SNK-P0037P
SNK-P0034P
SNK-P0033P
Intel® UP Systems
SNK-P0036
