Tom's Hardware > Forum > Homebuilt Systems > New System Build > Building Budget Workstation! HELP!
Forum Homebuilt Systems : New System Build - Building Budget Workstation! HELP!
APPROXIMATE PURCHASE DATE:
This month! With a budget of around $1300
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT:
3Ds Max animation, programing, Adobe Photoshop CS4 and flash CS4, surfing web
PARTS NOT REQUIRED:
Keyboard/mouse, monitor
PREFERRED WEBSITE(S) FOR PARTS:
newegg.ca, ncix.ca (In canada)
PARTS PREFERENCES:
Whatever you guys say is good!
OVERCLOCKING:
Yes!
SLI OR CROSSFIRE:
No
MONITOR RESOLUTION:
1680x1050
ADDITIONAL COMMENTS:
Basically a home workstation to do my animation using 3Ds Max. Would like to run Linux, but it seems the best way to run it is using windows, so I'll probably use XP, (32 or 64?).
CPU
Intel Core2 Quad Q9400 2.66GHz 6MB L2 Cache LGA 775 95W Quad-Core Processor - Retail
http://www.newegg.ca/Product/Produ [...] 6819115131
$254(CAD)
MOTHERBOARD
ASUS P5Q-E LGA 775 Intel P45 ATX Intel Motherboard - Retail
http://www.newegg.ca/Product/Produ [...] %20p5q%20e
$166
MEMORY
G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel Kit Desktop Memory - Retail
http://www.newegg.ca/Product/Produ [...] 6820231177
$155
GRAPHICS
PNY VCQFX1800-PCIE-PB Quadro FX1800 768MB 192-bit GDDR3 PCI Express 2.0 x16 Workstation Video Card - Retail
http://www.newegg.ca/Product/Produ [...] o%20fx1800
$500
PSU
SeaSonic M12II SS-500GM 500W ATX12V 2.2 /EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS Certified Modular Active PFC Power Supply - Retail
http://www.newegg.ca/Product/Produ [...] 0GM%20500W
$105
CASE
Antec Twelve Hundred Black Steel ATX Full Tower Computer Case - Retail
http://www.newegg.ca/Product/Produ [...] tec%201200
$179
HDD
Western Digital Caviar SE16 WD3200AAKS 320GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive - OEM
http://www.newegg.ca/Product/Produ [...] 0GB%207200
$79
OPTICAL DRIVE
Any DVD-R for 30ish bucks!
This is the basic setup I'm looking at right now. Looking to make sure its a good proper setup that can do everything i need it to, and hopefully last me a while too! Any advice to make it cheaper or better, in addition anything I might be missing. Any advice would be great, Thanks!
Sponsored Links
There's nothing wrong with your build, although an i7 system would likely be more upgradeable for the future.
Reply to stonebattle
I looked into the i7 and it was a couple of hundred bucks more, In addition would i need extra cooling?
Reply to dazzler54321
I'm not sure if your programs support that many threads, but if they do, the i7 would definitely be the way to go. For many applications, especially video editing, the i7 stomps all over the competition.
Reply to Fortunex
Indeed. But it will be significantly more expensive.
------------------------------ Phenom II X2 unlocked to four cores @ 3.8gHz,1.45V. 4GB DDR3-1600 Gigabyte 785g ATi Radeon HD4870 1GB
Run Folding@Home! Support Toms Hardware Guide, Team 40051!
CPU Buyer's Guide
Reply to smithereen
if you want an upgrade path, go dual LGA1366 workstation board with one xeon for now
Reply to mindless728
There are 1056 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
