NEED HELP!
Forum CPU & Components : CPUs - NEED HELP!
i am looking to buy a laptop and a BIG deciding factor is...
WHAT IS BETTER
AMD Athlon™ 64 X2 QL-64 Dual-Core Processor
OR
AMD Turion™ X2 Dual-Core Mobile Processor RM-72
Sponsored Links
i don't know what the real difference is. checking out amd official website, the specs are identical. same speed, cache, tdp, system bus, socket and 65nm process. i presuming that the difference is in architecture of the chip. since every other spec is the same, i'm assuming that the newer (RM) chip is going to be faster. either that or it's a case of rebranding.
------------------------------ Phenom II 955 @3.8 ghz|MSI K9A2 Platinum|500Gb Seagate 7200.11|2Gb OCZ Ram|Diamond HD3870 @800Mhz|CM 690|OCZ 700Watt |Scythe Mugen 2|
Reply to godless
from what i can read up right now, the chip performance is identical. the newer turion has more power states and can save more power @ idle. the memory has been upgraded to ddr2-800 and improved HT link
Reply to godless
i work at CDW and can get this:
http://www.cdw.com/shop/products/d [...] 536+Turion
*$30 upgrade the RAM
*Shipping cost of vista 64bit from Microsoft cheap
OR
i just get this:
http://www.bestbuy.com/site/olspag [...] 8093004316
what you think?
Reply to kamo287
pretty much identical laptops to me. same chipsets (3200) hdmi, hd, 4gb vs 3gb ram is not an issue. they will perform the same except the acer will have better battery life. the best buy one has LED backlit screen.
i guess i'd go with the acer, bettery life seems to be only big difference.
Reply to godless
+1 to godless...
The main difference would be the battery life and the Athlon would run hotter than the Turion...
So I would get the Acer...
Reply to gkay09
ok thanks. this info does help a lot.
i doubt it but the gateway might have DDR2 6400 ram- and the Acer 5400 ram- 800ghz and 664ghz right? would that make a big difference?
Reply to kamo287
^ I doubt for regular usage, you would notice the difference...Only intensive multimedia tasks such as video converting and other apps, you would notice slight difference...
Reply to gkay09
Tom's Hardware > Forum > CPU & Components > CPUs > NEED HELP!
There are 1240 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
