Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > [Solved] Power Supply Normal Fan Speed
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - [Solved] Power Supply Normal Fan Speed
Best answer from sminlal.
What is the normal fan speed for a PSU? (I know it will vary by model, but approximately what range?)
It's a 550W PSU.
I fired up PC Probe II for my Asus mobo and it gave me a warning saying it was only doing 41 RPM.
However, I can feel it pushing some air back there, about the same (or relatively close to it) as the case fan below it, which is spinning well well over that into thousands of RPM according to the probe.
So what is the deal, just an inaccurate reading?
PSUs with variable speed fans can operate with the fan stopped if the load is light enough. The "normal" fan speed depends entirely on the load - as long as the PSU doesn't overheat it should be fine.
I had the BIOS warning about low fan speeds and solved the problem by disabling it.
Sponsored Links
Does it feel hot to touch? Probably just inaccurate.
Reply to XD_dued
Best answer
Reply to sminlal
It's not hot at all. Feels cool, same with the air coming out.
Reply to templetonpeck
no worries then
as stated psu's with variable fans will slow down when they aren't needed
------------------------------ E8400 : GA-EP35-DS3L : mushkin 4GB DDR2 800 : HD 2600PRO : 450W ATX12V : Windows 7
Reply to 505090
I take it your PSU does actually have a fan speed sensor attached to the motherboard? Otherwise, the reading fom PC Probe II is not a reading of the fan speed.
At 41rpm, you would be able to see the individual fan blades as they rotate.
Andrew
Reply to Andy2008
There are 1173 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
