Wireless antenna enabling
Last response: in Windows XP
November 9, 2011 5:28:34 AM
Hello,
My other computer doesnt see any wireless networks but Im connected on this computer?
November 9, 2011 5:49:23 AM
your other computer must have in-built Wi-fi receiver in order to see wireless connection. else you should use USB receiver dongle..
Most laptop has in-built & some high end desktop boards also have this..
m
l
a b F Wireless
November 9, 2011 2:29:37 PM
This a laptop or a desktop? Is the wifi card installed properly, showing up in Device Manager? Is the computer in range of the router? Some laptop have a hardware switch to shut off the wifi card, check that. Also check the wifi software for an option to enable/disable it.
m
l
