Tom's Hardware > Forum > CPU & Components > Other Components > Graphics card and a power supply
Forum CPU & Components : Other Components - Graphics card and a power supply
Hey guys. Well, i need some help, i want to buy a new graphics card and a new power supply for it because the one i have atm is too weak. So i found this website to buy stuff from, www.scan.co.uk and i dont know which parts should i take. I was thinking about 4870 1gb.. but now sure if its worth it. My budget limit is 200£ (GBP). So can you please tell me which are the best ones? Thanks for the help guys. And btw my motherboard is not that new so i think wattage of power supply shouldnt be above 650.
Sponsored Links
What motherboard do you have?Also the new HD58xx will be shown to us in 3 days and will be available for purchase fairly soon.
Reply to Andraxxus
+1 on waiting up on the new parts from ati. or at least for a lower price of current generation cards as soon as the new ones come out.
------------------------------ Phenom II 955 @3.8 ghz|MSI K9A2 Platinum|500Gb Seagate 7200.11|2Gb OCZ Ram|Diamond HD3870 @800Mhz|CM 690|OCZ 700Watt |Scythe Mugen 2|
Reply to godless
Here the info i found about the motherboard.
Motherboard
Manufacturer: Asus
Motherboard Name: IPIBL-LB
HP/Compaq motherboard name: Benicia-GL8E
HD58xx versions? what are the prices going to be for them?
Reply to Robertas
most likely 250/220 -400 range hard to speculate especially if there's going to be another price war between amd and nvidia.
Reply to godless
Omg thats too expensive for me, my limit including power supply is 200, maybe +20
Reply to Robertas
INCLUDING the power supply. then you want to stick to 4870 1GB. but then i would wait for the new generation cards to come out to be sure/ prices of current gen cards to come down a bit.
oh and i meant us dollars in us. don't know anything about prices in uk. sorry about the confusion
Reply to godless
WEll by looking at this website, www.scan.co.uk is it possible for you to determine how much? If not, can you at least help me to get the power supply for 4870 1gb, because im not sure if i will get right one, because of these SLI or what ever connections.
Reply to Robertas
Reply to godless
here is a 4870 with 1gb ram
http://www.scan.co.uk/Products/1GB [...] HDCP-Ready
113 gpu + 68 PSU=181 pounds or dollars ( i don't know)
Reply to godless
I guess ill take the first one. And i guess ill take this graphics card
http://www.scan.co.uk/Products/1GB [...] isplayPort
So thanks for the help godless. thanks a lot. :)
Reply to Robertas
here's another 550watts
http://www.scan.co.uk/Products/550 [...] Active-PFC
it seems that all the 650watts are out of stock. dont know if you want to wait till its in stock. not too sure how well this site operates.
Reply to godless
no problem. good to see that you are still under your original 200-220 budget.
Reply to godless
Oh i havent seen the one you showed, the graphics card i mean, the one you showed looks better in specs. as i understand. will look at it
Reply to Robertas
plus i think that the cooler for the card would be better as well.
Reply to godless
There are 519 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
