Hi,
Problematic hard drive had a bsod after trying to change system performance settings to increase hd space used as virtual memory.
Chkdsk ran upon reboot, caused - error "A problem is preventing Windows from accurately checking the license for this computer. Error Code: 0x80070002"when logging into any Windows XP profile, default administrator account included.
With original windows xp CD attempted to boot into dos to do a regsvr32 / appropriate dll's to correct this problem - however Windows XP CD dos mode only offers a limited number of dos commands to be ran.
Since I'm unable to login to any windows profile successfully without this error causing the computer to restart I am asking for any ideas to try to successfully boot back into the system.
I can ultimately plug this hd externally, copy all my files, reinstall and get things back running but before that I want to try to fix this problem and get logged back into windows if its feasible.
Is there a means to run additional dos commands that are not by default included with the windows xp cd?
Are certain dos commands like regsvr32.exe and rstrui.exe (system restore) only runnable after successfully logging into windows?
Thanks for any help.
Tom
Tom
