Just Purchased Used Water System, Need Advice
I am new to Koolance, and water cooling in general. I just picked up an entire Koolance system, used off of craigslist today. I first need to find out what model each item is so I can start doing my own research. Problem is non of the items say much more than Koolance on them.
Drive bay res/pump combo, serial number: RP1007030068:
First which model is this?
Second here is a picture of the top plastic: http://brown-systems.com/water/crack.jpg . There is a crack on the plastic, does that pretty much make this trash or should I be able to patch and use it? Haven't tested it yet.
Radiator:
What model is this?
Pic: http://brown-systems.com/water/rad.jpg
CPU block:
Pic: http://brown-systems.com/water/cpuBlock.jpg
What model?
I hope to use this on an I7 920, but will be testing the whole system on an old socket 775 system first. Will this work for socket 1366?
I have Two of these GPU blocks:
Top pick: http://brown-systems.com/water/top.jpg
Bottom: http://brown-systems.com/water/bottomGPU.jpg
Model?
I got all of this plus tubes, connectors, and a bit of coolant for $80. How did I do?
Thanks in advance
2 answers Last reply
More about just purchased water system advice
  1. My advice: Don't buy a used water cooling syste--
    Oh.
    Too late.
    Can't you contact the seller and find out this info? I would have gotten that info and done some research before making the purchase.
    Edit: Good luck! Hope it works out for you.
    Oh.
    Too late.
    The seller new less than I do. I got it in a combo deal with a bunch of other PC parts.
    Thanks anyway!
Water Cooling Overclocking
