Sign-in / Sign-up
Solved
Gtx 580 overclock help
  • Graphics Cards
  • Gtx
  • Overclocking
  • Product
a b U Graphics card
May 1, 2011 2:34:32 AM
So my stock settings are 797/1594/2025 on my evga gtx 580 watercooled
i can use these settings stable
825/1650/2050 and vcore 1.138 speed 955/1910/2200
I get higher fps in all games and benchmarks with my stock settings wtf?
Anyway all my monitoring programs show everything correct so what is the issue here specs are in sig
More about : gtx 580 overclock
May 1, 2011 2:46:06 AM
With a GPU overclock you should have higher performance..
Maybe decrease in performance was caused by having some extra program running in the background.
While you are trying to fix the issue, I would suggest tightening your system RAM timings. Set your timings to 9-9-9-24.
m
l
a b U Graphics card
May 1, 2011 4:01:24 AM
That part is all good to go running evga oc scanner i get much better fps with the stock then overclock that even on the oc scanner benchmark. I really dont get it at all.
m
l
Best solution
a b U Graphics card
a c 351 K Overclocking
May 1, 2011 1:39:44 PM
Even watercooled, GPUs fail at a much greater failure rate than overclocking your CPU does, what program or game would you possibly need to overclock a 580GTX for?
That's such an unnecessary risk for a 500+ dollar computer component and with water cooling a 600+ dollar GPU, all it takes is one memory chip not making good enough contact and your GPU is a crippled lost performer.
I stopped OCing my GPUs some time back, they were just getting too expensive to risk damaging them, and I cannot imagine any of todays programs that would require overclocking a 580GTX anyway.
Maybe for bragging rights, but that's a high price to pay to satisfy your own curiosity, because no one else really cares!
a b U Graphics card
May 1, 2011 4:46:07 PM
Best answer selected by cia24.
m
l
