I am having a problem with my monitor staying in standby mode whever I have to reboot. It seems to only come on if I wait a while to boot and can hear the fan spin up, then I know it will come on. I have disabled the standby options in power management, tried another monitor/cable, and a clean install of the drivers, and checked to make sure the card is seated into the motherboard. I have also updated the firmware via asus update utility and tried clearing the cmos by removing the battery and changing jumpers back and forth.
I am suspecting a posting problem with the memory? Is there a process of elimination i can try to check each stick or any other ideas to consider?
I am currently using windows vista home 64 bit and specs are as follows.
Motherboard ( Asus P6T Intel X58 Chipset CrossFire and SLI Supported w/7.1 Sound, Triple-Channel DDR3, Gb LAN, S-ATA Raid, USB 2.0, 3-Way SLI PCI-E MB 3-Way SLI ) Memory ( 6 GB [2 GB X3] DDR3-1333 Triple Memory Module Corsair Value or Major Brand ) Video Card ( NVIDIA GeForce GTX 260 Core 216 896MB w/DVI + TV Out Video )
