I am using ASUS Turbo V Evo software that came with my motherboard to do overclocking. Im fairly new to overclocking so i need some opinions on some aspects. I did the autotuning, and it has my CPU runing at 224, which was unstable, so i have it running at 220 mhz. I read that the computer will set the cpu voltage higher than it needs to be, and somehow can shorten the life of the vcore. My cpu voltage is currently at 1.4 volts. Is this too high. Do i just lower it a little at a time to see if it is still stable. What do you recommend. Just for reference, my CPU/NB voltage is at 1.25 volts and DRAM is at 1.545 volts. Thanks for your help.
Motherboard is ASUS M4A88TD-V EVO/USB3
CPU is AMD Phenom II X4 975 BE
and Power Supply is Eagle Voltas 600 watt
