I just ordered two Intel 120GB X-25M SSDs to use as Windows 7 boot drives (one for OS and another for pagefile/temp/etc). My current system is a RAID 0 array on 2 750GB WD750AAKS drives on the Intel ICH9R onboard controller . After moving the data stuff temporarily onto an external drive (to make everything fit on the SSD), I plan to clone the RAID 0 array onto the SSD. Then I will wipe the RAID 0 array and copy back the files from the external drive to use it as the data volume.
I have Acronis True Image 2011.
In theory I think it should work but I'm not sure, where is the drive letter managed after I clone onto the SSD? In other words let's say I initially install the SSDs they are assigned drive letters D:\ and E:\ - then after the cloning is complete I would want one of the SSDs to be C:\ and the second one D:\ and the mechanical RAID 0 array should ideally be E:\. Is this done in the Intel Rapid Storage Technology windows app or in the system BIOS? How do I tell it which is the boot drive?
p.s. Originally I purchased two SSDs with the idea of creating a RAID 0 for those, but after reading about TRIM, I probably won't RAID the SSDs in order to be able to use the TRIM feature.
