Help with verbatim hd
Last response: in Storage
Related ressources
The disk is paper thin and any unexpected jarring, especially dropping it creates a warp in the drive. It could also be just a mechanical failure. Unplug it to prevent further damage. Don't worry in many cases you can have the data retrieved from your hard drive
Problem Solved, but... If you don't speak Español use GoogleTranslate haha
La mayoría de los discos vienen en formatos FAT o NTFS, que son usados por PC y en su mayoría Windows.
Hay un paquete, que te permite poder ver tu Verbatim o Disco Portable en Leopard o Lion.
Yo tengo uno de 750Gb y vino con fomato FAT32.
Te dejo el nombre del Paquete, y talvez el Link
So Google this, " NTFS-3G " I dont remember where did a get from.
the .dmg name is "NTFS-3G_2009.4.4-legacy-catacombae.dmg"
Cheers
Moe
Ask the community
