I had a Tuniq Tower 120 Extreme mounted on my i2600K blowing air up. The heatpipes on this heatsink were vertically oriented and spanned a height of about 100mm.
I noticed that tipping my case forwards 90 degrees so that the heatsink's heatpipes became horizontally oriented dropped my temperatures by about 3C after a couple of minutes. The difference was detectable repeatably and I kept the case's front fan blocked while checking. So I remounted my heatsink with a 90 degree different orientation, blowing air out the back instead of out the top and with horizontally oriented heatpipes. Now under 8 thread Prime95 load I get about 54-55C at 4.4 GHz instead of 57-58C.
Does anyone have a similar experience with their heat pipes?
If this effect is generally true, it would be nice to put that in the sticky guide here.
