APPROXIMATE PURCHASE DATE: (im ready to purchase as soon as i finalize the parts list) BUDGET RANGE: (example: US$750-800)
SYSTEM USAGE: (Watching HD movies (Full blu-ray rips at 1080p res with HD bitstream audio) with no stuttering video or audio playback, playing the latest games (Fallout 3, L4D, etc.) at high / near full settings, surfing the net fast, running windows XP fast)
PARTS NOT REQUIRED: (keyboard, mouse, monitor, speakers, monitor)
PREFERRED WEBSITE(S) FOR PARTS: (newegg is the one i know best, im open to any other reliable/cheaper suggestions as well)
PARTS PREFERENCES: Intel Chipset
a graphics card that has HDMI out put to pass HD video and audio (if an HDMI port is not available within my budget than ill stick with DVI outputs),
a case big enough to fit recommended graphics card without blocking access to other parts of the board,
Not sure what is the max RAM i could put in my system on this budget - im guessing 4GB minimum
OVERCLOCKING: Yes- but not very knowledgeable in how to do it
SLI OR CROSSFIRE: No I would like to stick to a single card
MONITOR RESOLUTION: (LCD monitor is 1680x1050, will connect HDMI cable from graphics card to a 1080p plasma HDTV)
ADDITIONAL COMMENTS: well basically i want the best PC build possible for my budget (i am willing to go over a bit if the benefits are signficant) Not really sure on things like mobos and graphics cards that best suit my preference, thats why I come to you guys. Please any help would be greatly appreciated. Im looking to finally have a great PC.
Message edited by nyboy42 on 06-07-2009 at 10:52:00 AM
Total Cost: $840.93 (Not Including Shipping, Taxes or MIR)
thanks for your list, a couple of questions: Why reccomend a triple core AMD instead of a quad core INTEL? how big of a difference would I see between the two? Also you reccomend 4GB of Ram, would i need a 64-bit version of XP in order to do that? Can you tell me more about the graphics card and why you chose that particular one? thank you
The triple core AMD is comparable to high end core 2 due Intel if you OC them.
Get the 4G DDR2 no matter which OS you will use because their prices are going up.
About the GPU, also consider getting two 4850 and crossfire instead. http://www.newegg.com/Product/Prod [...] 6814161259 If you do Crossfire, get a 750W PSU.
I wont reccomend parts, i will just tell whats the best (in my opinon) processor and GPU what fits into your budget.
-I recommend getting an Intel E8400, it will easily handle whatever you plan on doing. IF you want to go quad cores, then just get a i7 920.
-For a Card, a 8800GTS 512mb, will max out all your games except crysis in which case you will play on HIGH settings and not VERY HIGH. and costs around 100 dollars. However if you are going to be playing over 1680x1050, and play on your 1080p plasma then you are going to need something more beefy like a GTX260.
-Oh and Ram, 4GB will be more then enough, even for vista. UNless ofcourse you are going to be running super power hungry applications and will have many background processes.
how would you rate the Intel Core 2 Duo E8400 as compared to the Intel Core 2 Quad Q8400 Yorkfield 2.66GHz? both fit within my budget
Obviously the Q8400 would kill. The Q6600 is also an option. Although I'm a HUGE Intel Fan-boy, for your needs, a triple-core may indeed suit you best.
I chose the AMD build over the Intel build for cost reasons. I'm with raybob95 as being a HUGE Intel Fan but I also know that price to performance ratio you can't beat AMD. I tried to build the best system for your needs within your $800 budget. If you are not doing major video editing you won't see much difference, if any, between the two.
To see all 4GB you'll need a 64-bit system but as Helloworld_98 said don't get XP-64. Get either Vista-64 or Windows 7 RC - 64-Bit. However, you don't need a 64-bit system to run 4GB. I ran XP Pro SP3 with 4GB for a while just fine. If you want XP... stick with XP 32-Bit.
I chose the graphics card for two reasons, 1.) it is a great card able to meet your needs for 1080p and will max out any game at 1680x1050 (well maybe not Crysis... but what does... ). 2.) The board is Crossfire ready so it gives you the ability to add another one in Crossfire down the road when you have additional money.
Well ofcourse the Q8400 would be more powerful but the question is...
-Do you need it?
-Will you use the extra power?
-Do you want to spend the extra $?
-A core 2 dou will easily handle all of your needs, so wouldn't it be fine?
-Most, and I mean almost all applications today are optimized for 1 or 2 cores anyway, very few applications and software can utilize quad cores effectivly so consider that.
-Do you need it?
So you really think based on what I want for my build:
Play games in high settings in high res
Watching HD 1080p movies
Fast Windows applications and web surfing
that I should save money and go for a core 2 and not quad? If very few applications and software utilize quad cores, then why are most people upgrading to them?
because the majority of people watch Intel advertisments and believe it -truth be told the majority of americans are mindless brainwashed liberals who can never think "outside the box" if you know what I mean. And becuase of this Intel makes a lot of $ from it, however new processors are always going to be quad core since technically they are more powerful and stuff, its technology taking its course basically.
-And yes I think you should go with a core 2 dou to save money and spend some more on a good GPU instead which will help alot more in games and 3d applications.
