Help pc won't start after oc
Anonymous
a b K Overclocking
May 5, 2011 7:05:57 PM
Ok i just tryed to oc my i7 960 on a r3e mobo and my temps were in the low 30s on the crazy oc profile(3,85x1.425v) but when i tryed to go to 4.0x1.35v it just froze so i turned it off from the power button and now it wont start at all i tried pushing the p button all over again unplug my pc from the ps and everything i tryed restarting the bios from the back button and from the one on the mobo and even tryed powering the pc from the start button from the mobo but it wont do anything.. Altougth my external hdd starts spinning when i plug the pc on and the mobo lights are on but nothing happens
Sry cuz im messed up but its late im tired and i really need to fix this fast
Mobo: asus rampage 3 extreme
Cpu: i7 960
Psu: chieftec 1000w 80 plus silver
Gpu: gigabyte gtx 480
Ram: kingston 6gb@1600mhz
Hdds: 64gb ssd boot drive + 2x500gb raid0
More about : start
a c 286 K Overclocking
May 5, 2011 7:36:10 PM
Hi and welcome to Tom's forum.
Remove the RAM, reset the BIOS, install the RAM and try again.
a c 197 K Overclocking
May 8, 2011 1:09:56 PM
Yep, reset the BIOS and try again..
That is one reason I like Gigabyte motherboards. If you overdo an OC setting, they will generally try to find a bootable configuration.
