Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Front audio connections
Forum Homebuilt Systems : General Homebuilt - Front audio connections
i have just built a system with a ezcool m-60b 500w case and a gigabyte g31m-es2l mobo the problem i have is that there is one green wire that comes from the front panel with an eyelet for a screw on it that i dont know where to connect it to any help would be appriciated
Sponsored Links
Sounds like its a ground wire for the case electronics or case itself. What does your manual call it?
Reply to Twoboxer
- 0 +
no manual in case when it arrived so i connected to the case if u trace it back it goes into the front audio jacks but can't see where too as its enclosed in a plastic case
Reply to beario
Does anyone know if they make a front panel audio extension cable so I can route it behind the motherboard tray. The one that came with my case is too short.
Reply to ragsters
- 0 +
too new to this selfbuild game too answer that have to ask someone with more nouse
Reply to beario
Googled "front panel audio cable extender" and . . .
This forum link may provide your answer:
http://forum.coolermaster.com/view [...] =5&t=10506
Read a few posts and note issues/resolution.
Good luck.
Reply to Twoboxer
There are 1232 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
