Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Need some advice on a new build
Forum Homebuilt Systems : General Homebuilt - Need some advice on a new build
This will be my first home built pc. I have put together a list of components, excluding a video card(Im thinking dual 4850's) but my real questions are Will it work? and Will it work well? my budget is around $800 usd
For case and psu http://www.newegg.com/Product/Comb [...] mbo.198951
For mobo http://www.newegg.com/Product/Prod [...] 6813128358
cpu http://www.newegg.com/Product/Prod [...] 6819116091
cpu cooler http://www.newegg.com/Product/Prod [...] 6835233029
this ram http://www.newegg.com/Product/Prod [...] 6820231174
this hard drive http://www.newegg.com/Product/Prod [...] 6822148395
and some extra fans http://www.newegg.com/Product/Prod [...] 6835200051
I do plan to over clock
Thanks in advance
jack
Message edited by lumberjack4567 on 06-08-2009 at 06:49:39 PM
Sponsored Links
Yes, it's all compatible and it will work well. I prefer DDR2 800 RAM that runs at 1.8v and western digital hard drives.... but that's a preference. Good luck
Reply to dirtmountain
Thanks dirtmountain If you could suggest some good ddr2 800 i would appreciate it.
Any suggestions about a video card?
Reply to lumberjack4567
Here's a couple
http://www.newegg.com/Product/Prod [...] 6820146731
or
http://www.newegg.com/Product/Prod [...] 6820231209
If available, the HD4770 DDR5 (not the DDR3 one) It's just that the availability of this card is very bad, high demand, low 40nm yields.
Also check out the HD4850 or the HD4870 to check prices and deals.
I like the quality and warranty of XFX. Just be aware you can't collect on 2 rebates if they're sent to the same address. Not that i'd ever suggest you have one sent to a close family member or anything to get around that restriction.
There are 777 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
