First, a disclaimer -- I'm not necessarily looking to do any over-clocking -- but I figured this group would have the pro suggestions. I recently moved from a Q6600 on a P5K with 4GB and a Asus ATI 5770 running Windows XPsp2, to an i7-2600 on a P8P67 with 16GB and a eVGA GTX 460 SSC+ running Windows 7 Pro.
I'm apparently having some cooling problems.
First, I did the primary install with the stock Intel fan that came with the chip, using only the dab of thermal material included on/with the processor itself. Installed the OS, moved on -- was seeing a variety of 30-40c when idle with a little hotter specs in bios -- hovering around 60c in bios.
Then, I got back to work after reinstalling my apps like CS5 Photoshop/Premiere/After Effects. The GTX 460 and the i7 made Premiere Pro scream with HD like I'd never seen before -- but when I hit for a 5 min render, suddenly Asus AI Suite was screaming at me: my CPU had reached 85c.
Eventually after some testing with Prime 95, CPUID Monitor, and some side-apps like Real Temp, I came to find that on load after only a few minutes I was getting up into the 80s and 90s; one particular test one of the cores hit 96c. At this point, I called it quits.
Today, I figured I would go grab some AC5 and try to re-seat my old HS from my Q6600: an Arctic Cooling Freezer Pro 7 Rev 2 - ( http://www.newegg.com/Product/Product.aspx?Item=N82E16835186134 ). Went ahead with the installation.
Idles are now about the same place: varying between 33-38c across the cores. Load testing with Prime 95 has dropped to hover pretty solidly around 70c. There is some variation between 69 and 73 and it will come and go.
I am pretty certain I have some case cooling issues. I have an older ATX mid-tower circa 2002 that has a 120mm feeder on the front, and then plastic cowling on the exterior that seems to kill all air flow into the system. On load, air coming out is warm, but not uncomfortably so. Upon some more cash, I plan on building up a new case with new fans. I have tested with the case open and not -- seeing a difference of about 5-7c.
So, hovering around 70c at load on that Arctic Cooling HS -- is that normal, or expected? 80c/90c+ on load with the Intel stock -- is that normal?
At what point do you start wondering -- hmm.. I wonder if the casing is off with this chip and I should RMA it?
Thanks much. Any suggestions welcome.
