Tom's Hardware > Forum > CPU & Components > CPUs > Q8400 Installation problems
Forum CPU & Components : CPUs - Q8400 Installation problems
Just swapped out a Q6600 for a Q8400 due to a flawed core on my q6600. Anyways, problems began right away and in this order:
1. Boots, says BIOS requires update on my Asus PK5-E, Update BIOS to most recent from flash drive, Installs and verifies installation correctly
2. Boots to windows, try to run Everest Stability Test to help burn in the processor and heatsink, BSOD almost instantly upon start
3. Boots to windows, try to run Windows Experience Index, BSOD instantly
4. Boots past BIOS to windows message that ntoskrnl.exe is corrupted and to put installation disk in to repair file
5. put in installation disk, gives same error, won't proceed to repair option
6. restarted machine, now just blank screen, no BIOS post or anything
Any clues? we realized that only a 4 pin connection was in use on the 8 pin CPU power, so we swapped that for the full 8 pins, thinking it was maybe a stability problem with the CPU, but still not even a BIOS post.
Any help would be great, i have another identical rig, still using the old q6600 oc'd to a comfortable 3.2GHZ running just fine with the same BIOS ver as my crashed rig. This can be used to test out components, but i don't want to shotgun testing, i want to have atleast an educated guess as to what needs to be tested
thanks,
Ryan
Sponsored Links
take everything out, like add in cards (sound, modem, lan), unplug HD, some fans... u need to find out if its a power supply issue, u need to give the mobo and CPU all the power u can give it... and see if u get a post.
the next issue, could be... maybe u need a bios update... do some research, to see if u need a bios update for the cpu.
hope this helps.
------------------------------ AMD Phenom II AM3 X4-Core 3.2Ghz-955 (O.C.3.8Ghz) / ASRock 10N780SLIX3-WiFi - MOBO / gSkill CL5 = 8Gigs RAM
AZT-FORTE X-Fi 7.1-Surround Sound / GeForce 9600-GT 512MB (X-2) / WD 500GB HD 7200 Sata-3 / Acer 23' X233H LCD Monitor
Reply to renegeek
There are 1180 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
  • 01:00 xpax won the Freshman badge
  • 01:00 Mizoguchi won the Freshman badge
