Tom's Hardware > Forum > CPU & Components > CPUs > Extreme overheating
Extreme overheating
Forum CPU & Components : CPUs - Extreme overheating
hey, i just installed a new heat sink and fan and i got 80 c idle temp and 120 c (shutdown) temp.) Ive applied thermal paste. Please help.
Sponsored Links
Its not making correct contact with the chip. Reseat it
Message edited by PsychoSaysDie on 09-11-2009 at 05:44:39 AM
------------------------------ E8600 @ 5.2Ghz 1.5v
4GB DDR3 2000
Intel X25-M
XFX 5770 In X-Fire
Reply to PsychoSaysDie
Ive reseated it now idle is at 60 and full load is 80c.
It's still too hot...
If i touch the heatsink, its cold, and the CPU is medium. Could it be a sensor?
Message edited by maypep_necro on 09-11-2009 at 05:56:43 AM
Reply to maypep_necro
------------------------------ "To better understand why you need a personal computer, let's take a look at the pathetic mess you call your life."
Reply to badge
Yes, i<ve followed the instructions. It<s been working since 2005.
Well, which HSF are you installing onto which MB? What is the Vcore (voltage to the CPU) in BIOS? What CPU are you using? The temps seem high, how or what software are you using to measure the temperature of the CPU? I only ask this beause these are the appropriate questions to ask in this situation.
Reply to badge
Quote :
You found the cord for the PSU. How about this stuff? Has time provided answers? I can point you apps that cold provide clarification if any confusion still exists. :??:
GFX card: Unknown
Sound card: None
Network card: Unknown
Reply to badge
lol, not that computer XD
You were on by that time:O This goes back to 2006 :O
Whatever, My Vcore is 1.25
I<m using Pentium D 2,8 GHz, (Presler)
And im using BIOS and Everest ultimate to see my temps.
I have a pentium D 925 running currently. 60c is not that far off, a little high with stock cooling. Properly positioned case fans directing fresh airfow front to back of the case will reduce CPU and other MB chip temps considerablly. My 925 D is a Micro build in a small case with 'restricted' airflow. With the stock Intel HSF, I believe high 40's idle with an immediate jump to 50-51C under small load. I installed this Zalman HSF and my CPU temps idle are low to mid 40's, moderate load under 50C. The system runs all day at a workstation. At any rate, if using the stock Intel HSF they can be pain to get right. You might try pushing down slightly on the top of the HSF and observing the CPU temps. If the temp goes down when pressing the HSF against the CPU, the installation is bad. Best I can do with it.
http://www.newegg.com/Product/Prod [...] -_-Product
Reply to badge
Nope, temps arent better when i press on the hsf.
Is my CPU fried???
There are 1189 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
