Hello all,
Well I will get this PC after few weeks as I hope and I will try to replace some of the parts to be better for gaming but I need your advice on all the parts in general.
It was mentioned in the site by 4 GB but in the PC its written 3 :S
350 Watt Power Supply
duno which brand
here are the important things in the PC, and the things that I want to change are:
Adding new Graphic card
Sapphire ATI Radeon HD 4870 1 GB GDDR5 Dual DVI/HDMI/TV-Out (PCI-Express)
well i think you could step down the power supply to the 500w one they have on that same website...as for the video card, the price on that video card is really inflated (but I guess thats what happens when comparing prices in Bahrain to US prices)...
Don't use that motherboard. If you must use this site, then get the G31 board for the same price.
None of the lower wattage Cooler Master power supplies they list are very good.
I see they build the system you order for free, which is nice, but perhaps you should check with a local shop and see what they will build for you and how much it would cost.
This site claims to have very high quality parts but I'm not seeing it.
I am working in Saudi Arabia, and upper end parts are more expensive. And beleive it or not, in this part of the world, CoolerMaster PSU's are one of the better brands available.
Yep. I know I helped someone else in Bahrain a few months ago and we got something together that I was satisfied with, but he may have had a larger budget.
The board you picked supports DDR2 800, and you've picked a higher voltage DDR2 1066. It may work, but it will downclock. You may want to look at some DDR2 800.
