Hello, I'm having a temp/performance/cost dilemma with my "legacy" am2 build.
Rig:
Lian Li PC-60(b?) Plus (mid tower)
PCP&C Silencer 750w
Asus Crosshair v1.04
AMD FX-62 (AM2, 2.8GHz)
2x2Gb PNY DDR2@800MHz, dual channel
1x 8800gt g92 512mb (soon to be 2x)
2x SATA-II hdd's
Ambient temps will likely be ~80F, peaking close to ~90F, for the next 4-5 months.
Building a new system is out of my range, so i decided to add a second 8800gt for SLI, and go for the best cooling per cost, so i can squeeze the last bit of life out of my cpu... while i wait and gather resources for my eventual new-full-build.
I want my fx-62 @ 3.2, and my (soon to be)2x8800gt to not melt.
I have a zalman 9700cnps (the nickel plated one w/ the green led... not the oldest/smallest, or the newest/biggest), and it's just not enough for any 'useful' OC. I can hit ~3.0+, but anything 3.1 or higher is just too hot. My current single evga 8800gt (g92 512mb) almost melts itself with any modern game. I've seen it break 100C, several times... yet it hasn't died, so far.
My question is this:
With the newer Air coolers available, is there any real reason to water-cool this?
My options are a custom WC build, including 2 DD-IONE blocks, and mostly koolance blocks for the CPU/MB/NB/SB...
Or...
1x thermalright 120 (or maybe a "silver arrow")
2x T-rad2 GTX (fits 8800gt-512mb-g92, according to compatibility chart)
?x "many fans"
I have no prior experience with water cooling, but have been doing research for several days, and it looks quite appealing.
Air is cheaper, but case gets full of dust, and might not cool as well, or even enough for an OC.
Air requires little maintenance, but requires purchase of either canned air, or a compressor, or bringing my tower to someone who has one.
Water is usually more effective, more complicated, more risky, more expensive... but i wouldn't have to bring the tower anywhere to purge/refill/burp.
Water? Air? OC as-is, let it melt, and just have no PC until the end of the year? lol.
Idk what to do.
I really want to go WC, but it seems to expensive.
I really like some of the air-cooling products i've seen recently, but with my unavoidable high ambient-temps, i doubt air will be enough.
Help!
Rig:
PCP&C Silencer 750w
2x SATA-II hdd's
Or...
?x "many fans"
Idk what to do.
Help!
