Hi everybody
I just installed a 5.1 digital surround sound system with a spdif connector which has been sitting around the house for a while, when I set it up i went into the control panel sound settings and set the speaker settings to 5.1 surround and then went into the soundmax control panel and that had 5.1 selected but it was trying to find the jack connections for the front, rear, centre and sub which i had not plunged in coz the amp only has a spdif connector. but i try some stuff out. when using powerdvd i got full surround which was cool, but when i booted up a game I got only normal stereo no of the other speakers were giving out sound, so i have been searching the help section in the soundmax and that said that the spdif controls were under the general tab so i looked there and the only option was disable digital and swap centre/sub. so i look on the net and found that soundmax does not have rights to Dolby digital and that i need the and EAX to use surround with games and music through a spdif connector (it seamed a bit daft to me to have the connection on the mother board if they have not got the licence to fully use it but hey,) so i found that the cheapest option for me was to buy a sound card, and what i would like to know is is the information that i have picked up correct and will getting a Auzentech X-Tension sound card fix my problem.
if some one can reply to give me an answer i will be very appreciative.
