I recently built a new system with a Asus M4A78 MB. When i boot up the system with all 4 2gb ddr2-800 sticks in the system freezes during the bios screen. When i took all but one of the sticks out and left the one in slot 1 it booted up fine and i was able to install the OS. I then updated the BIOS from the ASUS utility. Then I added a second stick with no problem to slot 3. I have tested the other two sticks and I don't think they are the problem. Is my MB bad? Do I need to set do something different with the BIOS?
Here is my system
Asus m4A78 with Phenom 965
The Ram is *gb ddr2 from http://www.enetshoponline.com/mm-rx8002g-m.html
Gigabyte nvidia GTS 250
seagate 500 gb HD
DVD burner
Coolermaster V8 CPU cooler
Power supply BGF GS 550 W
let me know what you all think. Thanks
Here is my system
seagate 500 gb HD
DVD burner
