Surround Sound
Forum Homebuilt Systems : General Homebuilt - Surround Sound
I just built my first computer with help from the awesome people at this forum. I have a question about HD and surround sound audio now. Here's my current build:
core i7 920 @ 2.66 GHz
6 GB OCZ DDR3 1600 MHz (at 1066 MHz)
Western Digital Black 640 GB hard drive
Intel DX58SO Motherboard
HD Radeon 4870x2
Pioneer DVD drive
My question is this: from the specs of the motherboard
Channels: 7.1 Channels
Audio Chipset: High Definition Audio (HDA)
Does this mean that I should be able to buy some 5.1 or 7.1 channel speakers and a blu-ray drive and expect to get the best of HD audio? I saw some HD Audio pins on the motherboard: do I need to buy some other peripheral to connect to those in order to get HD sound? Basically, what can I do to turn this into the receiver of a surround sound system???
Sponsored Links
Do you have digital audio output on the motherboard?
Reply to doormatderek
I looked it up and yes you do. Although you will need an amplifier to power all the speakers.
It has optical out. And the connections pictured here: http://www.tigerdirect.com/applica [...] CatId=4070
Will this support a traditional 5.1 speaker setup? Are there bandwidth issues? I just need to make sure. If it does, I will definitely get some speakers and a blu-ray drive.
Reply to mortonww
Oh. Cool. So the setup would be a line out from the back of the pc to the subwoofer, speaker wires from the sub to all of the speakers....and how does the amplifier fit in?
Reply to mortonww
Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Surround Sound
There are 1324 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
