Tom's Hardware > Forum > CPU & Components > CPUs > [Solved] Lock up issue
Forum CPU & Components : CPUs - [Solved] Lock up issue
Best answer from Twoboxer.
hello all i need some serious help i recently built my
first pc last month and i have been having
a issue with my pc locking up but it does not lock up
at random times. but when i play a game or
trying to burn a DVD.... i can burn CD's with no
problem and also when i try and watch a blu ray
movie it locks up... when im watching a regular DVD I
have no problem. i can leave the pc running all
day long and surf the internet and it will not lock up at
all these is the hardware from my PC
everything is new except for the hard drive i got it from
a co-worker, but the hard drive was still
wrapped up and was never open. But now it's starting to lock up at random now
power supply:ultra X3 850w
DVD player: lite on 6X blu ray
ultra usb 2.0 md3 5.25 multi function panel
case: ultra m998 mid tower
ram: OZC reaper 4096MB pc10666 ddr3 1333Mhz
(2x2048)
motherboard:evga nForce 790i ultra SLI socket 775
CPU:intel core 2 quad Q9650 3ghz 12mb 1333 fsb cpu
video card:bfg geforce gtx 285 oc 1gb PCIe b edition
HArd drive:seagate barracuda 1tb 32 mb sata hd
operating system: windows vista ultimate 32-bit
any advice would be helpful. thanks all in advance
Quote :
Prime 95 will run "forever" unless you stop it, or something fails.
So something failed.
64C after 45 minutes is OK.
Repeat the test with one stick of RAM . . . run 90 minutes if you can . . . and then run it again with the other stick.
Sponsored Links
Was the Vista fresh installed?
You don't mention ever having stress tested the PC. If you haven't, download Prime95 (detect rounding errors checked) and run for an hour using CPUID Hardware Monitor to monitor temps. Let us know.
If the OC on the 285 is not factory, go back to stock. Same on the cpu for an OC there, if any.
Reply to Twoboxer
Hehe. A more concise reply than usual.
Reply to Twoboxer
It didn't show up but 45 min in the test my pc had locked up didn't really finsh the test
Reply to Peako216
But in the process of the test my CPU temps got up 64c and my ram was at 3.2gb
after the 8k test it locked up... I have the data for the test on my email address but I guess it didn't submit it correctly on the fourm
Reply to Peako216
Best answer
Reply to Twoboxer
Ok just ran the test with one stick a ram the first was fine no problem... Some with the second stuck of ram except for when i was about to ran the test the pc locked up but the second time there was no problem... CPU temps was 61c at the highest for both
Reply to Peako216
pc have been running for 2 days now and have not locked up yet, im even able to play games with no problem it most have been my ram probably wasn't seated properly but all is good now thanks for the help twoboxer
Reply to Peako216
There are 1161 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
