Antec 300
Antec 550w PSU
Panny DVD Burner
Hitachi 500GB SATA Drive (With Windows 7)
WD1200GB IDE Drive (With JUST XP on it)
WD 500GB SATA Drive (Storage)
AMD Phenom II 720 Black Edition
Asus M4A78T-E
G.Skill 4GB DDR3 1333
Video Card (primary): Radeon HD 4850
Video Card (secondary): Radeon HD 4550
Currently all I did was change the memory timing on my motherboard to 8-8-8-21. Speedfan has my Temps at CPU: 37c, Mobo: 36c, Core:27c 8850: 40c at idle and CPU: 43c, Mobo: 40c, Core:36c 8850: 66c max while playing Crysis . Are these temps good? Im using stock HS Fan with OCZ freeze.
I want to OC the CPU a little bit while keeping everything stable and the temps low. Can anyone advise on how to do this? I also want to run some benchmarks to make sure Im up to snuff and everything is all good. Can anyone reccommend some benchmarks for this?
Also, I left my old PC on 24/7. This time around Im wondering what the best way to do this is. Right now I leave it on 24/7 but have it go on standby after 30 minutes which seems to turn off all the case fans etc. What is the best method for this?
Thanks all!
Message edited by JSD13 on 06-15-2009 at 06:07:44 PM
Standby is fine. If you want to OC, I'd read the sticky in the OC forum just so you're familiar with what you're doing.
For the BE pii CPU's it's really easy to OC. Go into the BIOS, bump the multiplier, boot and run prime95 stress test for ~15-30 mins. If stable, bump the multiplier again and do another stress test. If p95 won't run, go back into the BIOS and bump the voltage and rerun stress test. Monitor your temps constantly. Max temp for the 720 is 73 degrees, but common practice says keep it below 50-55 at full load.
Repeat until you get uncomfortable, you're voltage hits 1.5 total, or you're temps get too high.
I don't see an after market cooler on your list, you'll need one to OC. I recommend the Scythe Mugen 2.
