CPU: Athlon II x2 240
MOBO: GIGABYTE GA-MA790X-UD3P (AM2+)
RAM: 1x 1GB DDR2 800Mhz + 1x 2GB DDR 800Mhz - Edit: Oops, accidentally put 400Mhz instead of 800Mhz.
GPU: XFX 9600GT 512MB
HDD: 2x SATA 3.5" 7,200 RPM
DVD: 1x DVD-RW
Others: A USB powered MIDI keyboard + an external USB soundcard (however it's not powered via USB, it has it's own power adapter)
Now I've been looking at a few power supplies available in Croatia. There are some cheap Xilence 800w power supplies, but I've read mixed reviews about these. Other brands include Antec, Corsair, Thermaltake, Coolermaster, OCZ, altho some of these can be quite pricey. I'm not sure just how much power I will need to power this rig. So could you give me your recommended Wattage estimate? I want something stable, and if it's possible not too loud. I don't mind about cable management or modularity. If you could recommend one of these brands/products, that would be cool.
Cheers!
Message edited by Malevol3nt on 09-14-2009 at 03:03:14 PM
You'll need a power supply with at least 1 PCI-E connector and 20A on the 12V rails (240W combined maximum wattage), but 22A would be better: the OCZ Stealthstream 400W would be a good choice, or the Gigabyte Superb 460W, or the Antec Earthwatts EA 380.
I agree for OCZ 400w and EA 380 suggested by Gulli.
Don't go for any unknown brand.
Like that Xilence.They will always cause trouble.
They might go boom or the fan would make noise.
Another option is Corsair CX400.Decent 30Amps on Single 12v Rail.
Hmm. Well the thing is, I had a rig before this with a Fortron 400w PSU. The specs were similar to this one except I had an older Athlon x2 5600, a different mobo and an older ATI GPU. But as soon as I bought the 9600GT the whole system was getting slow, some games would have alot of input lag, and the system would sometimes not boot at all. I tried using the 9600GT on my friends PC with an even slower CPU (but a better power supply) and everything worked out ok.
So I want to be safe and buy something a little bit more powerfull than 400w. I guess a Corsair or OCZ with 500w and the specs you guys provided would be ok.
yep at least. Power.s last for years and if you decide to get a more powerfull card or upgrade the mb or cpu its better to have and not need than to need and not have ..
500w+ my recomindation
Message edited by sirkillalot on 09-14-2009 at 03:48:17 PM
i have a tagan 1100 Watt psu but for your system and for further system upgrades i suggest you a
Tagan TG700-BZ PipeRock 700W about 130€
or
Corsair CMPSU-650TX 100€ but you kann also get a other one with 50 Watt from superpower it is strong enaugh but not a really known brand spec: Gaming Power Suply ModelNo: SPS-750SP.(14)
i have a tagan 1100 Watt psu but for your system and for further system upgrades i suggest you a Tagan TG700-BZ PipeRock 700W about 130€ or Corsair CMPSU-650TX 100€ but you kann also get a other one with 50 Watt from superpower it is strong enaugh but not a really known brand spec: Gaming Power Suply ModelNo: SPS-750SP.(14)
hope i could help greets laluma22
1100W? The OP wants to power a dual core PC, not a Las Vegas neighbourhood.
Message edited by Gulli on 09-14-2009 at 07:39:45 PM
or
hope i could help
greets laluma22
LoL.....
Will surely power a cyber cafe...........
Damn, the new Athlon II X4 are out and they seem really great for the price. I still haven't ordered the PC parts from my list, paycheck arrives only later this month. I wonder if these will be available any time soon over here (Croatia). Since I'm going to use the rig for audio production/editing, more cores is a plus.
i know malevol3nt so if you want to take a athlon II X4 and you do own a am2+ motherboard so i would then recomend you the x4940 Be box 3,0Ghz
but if you do not own a am2 + socket and you still want to upgrade maybe you should take the x4 955 3,2 Ghz and a am3 socket mainboard with ddr3^^ so think about it and get back to me or us here some links where to buy my fried
Damn, they're already in the local shops. And the price is very attractive. Ok so instead of the Athlon II x2, I'll rather go with the new Athlon II X4 620.
What are your thoughts on the Antec PSU ANT Truepower TP-550EC PSU (550w)? It seems to have good reviews on hardware sites. Will 550 Watt be enough? Of course, it's not a 100% efficiency PSU, it says 85% which I hope is true.
well i can not say you if it is enaugh i think not and about the psu i ahve a tagan 1100Watt and it has a power eficienc of 89% probably you wont find a psu with 100% thats what i think cause all i know have around 85% to 93 or smt like that so if you want to b on save side take a 700W like that one
OCZ power supply GameXStream 700W, SLI-ready, crno, EPS, ATX 2.2, 4×12V (72A), 12cm blue led FAN 809kn vemil.hr^^
or also check out hgspot.hr they had some time good offers and they still have some not so much^^
greets laluma22
btw look at your graphic card how m. watts does it use on load i think schould not be more than 350 and the cpu arround 130WATT so probably and mybe 550 are enaugh but go on the safe side for further upgrades
Yes, it will be enough, though 12V rail watts are more important than overall watts, but the Antec 550W has plenty of 12V watts. The efficiency is the ratio between what the PSU delivers and what it draws from the wall: your 550W PSU can actually deliver the full 550W to your PC, but at 85% efficiency it means it will draw 650W from the wall, the rest gets dissipated to heat inside the PSU.
Message edited by Gulli on 09-16-2009 at 07:12:53 PM
------------------------------CPU: Intel Core i7 920 @3.2Ghz, MOBO: Asus P6T SE, RAM: 3x 2gb OCZ Platinum OCZ3P1600LV6GK, GPU: Sapphire HD 5870, PSU: Corsair HX520W, HDD: Seagate ST31000528AS 1Tb 32mb, COOLER: Scythe Mugen (S775 version), CASE: Coolermaster CM690
Reply to Gulli
