Prompt problem
Hello,
when i open my pc prompt c appear like C:>1 and window is not uploading.what can i do?
2 answers Last reply
More about prompt problem
  1. jasmine_10 said:
    Hello,
    How are you getting to the command prompt ?
    What are you expecting to load, Windows won't load !
    Start > Run > cmd
    Your prompt should be:
    c:\Documents and settings\???
    (where xxx is your logon)
    try entering these two commands
    c:
    cd \documents and settings\???
  2. Ok... we need more details!
    U try to open Windows and U get a cmd window?!
    Does it actually boot into Windows and after that a cmd opens ? If so, U probablly have something that can't load quite normally (a service at startup maybe)
    Go to start>run and type msconfig and go to startup tab and uncheck what U think it's weird (any %#!@%^....stuff like that ) things you don't need or aren't vital.
    Or, if that's not it, U can't get into Windows?
    Are you at the recovery console by any chance?! (have U pressed R key?)
    :hello:
Configuration Windows XP
