Tom's Hardware > Forum > CPU & Components > Other Components > Razer mice double-click
Forum CPU & Components : Other Components - Razer mice double-click
So here's the problem:
I have 2 Razer brand mice. 1 Copperhead, 1 Krait. Both of them occasionally double-click when there should only be a single click. Its an annoying little problem that ONLY shows up on this machine in Windows XP. If i boot up my windows 7 partition, I do not have double-click issues, nor do the mice have the same problem on other computers that have Windows XP.
My first thought was "its a driver problem", but I've had no such luck uninstalling and reinstalling drivers. What do you guys think?
Sponsored Links
Starmage21,
Microsoft does have an official Windows 7 Support Forum located here http://tinyurl.com/9fhdl5 . It is supported by product specialists as well as engineers and support teams. You may want to check the threads available there for additional assistance and feedback.
Jessica
Microsoft Windows Client Team
Reply to JessicaD
Your mice are so Razor Awesome, that your computer is too slow to comprehend its motions and actions. Its like a HOT supermodel with me. I would be looking at her, that when she looks at me I would spaz out tring to act all normal...
Anyway... I would do JessicaD's solution.
Message edited by dragonfang18 on 09-16-2009 at 07:25:15 AM
Reply to dragonfang18
JessicaD wrote :
Starmage21,
Jessica
I'm not having a problem with WIN7, I'm having a problem with the mice on XP on this machine only. If I boot WIN7 the mice work fine.
Reply to starmage21
just wanted to give this the old bump, issue has not been solved yet.
Reply to starmage21
There are 1166 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
