Tom's Hardware > Forum > Graphic & Displays > Nvidia > GTS 250 Problem Please Help
Forum Graphic & Displays : Nvidia - GTS 250 Problem Please Help
I just bought a GeForce GTS 250 video card, and my power supply is 650 W the name of the brand is Topower, everything is well when i start my game Far Cry 2, my settings are high , i play like about 3 minutes, then my computer like crashes, and my monitor goes to sleep,and i have to shutdown my computer,any help will me great, this happens to all my games, thanks in advance, if you need more info i can tell you.
My computer is a Hp Pavilion a6707c
Sponsored Links
Join the club of the Nvidia GTS 250 Disappointed and Almost Neurotic Users, mine has been doing that randomly once a day in any game I play.
First please post all your PC's specs.
Then use GPU-Z to keep a track of your GPU's temperatures, and go play, whenever the thing crashes post the temp log that the program creates just to see if it is a heat issue.
Also check if the GPU is properly connected to the PSU and if it's well fit into the PCIe slot on the motherboard or if the fans work properly and are not obstructed by any cable.
A partial solution could be using EVGA's Precision Tool to manipulate the fan speeds of the GPU, you may set it to 80-100% prior any gaming activity and try to play for a while.
Regards
.C.
Reply to CefVil
man what is the 12V u have on for ampires the GTS 250 needs 12V@24A
Reply to asiff6000fx
If nothing works out after doing what cefvil said, then change your PSU to a good 80+ brand like Corsai, PC P&C, Seasonic, OCZ, Antec earthwatts or cooler master REAL POWER (not extreme power). a 450W unit should be enough from any of these manufacturers.
------------------------------ AMD Phenom II 720BE, ASUS M4A78T-E, 4GB Transcend DDR3 1333MHZ, Powercolor 4870 1GB DDR5, Corsair 750TX, WD 1TB Green, Maxtor Basics 500GB, Logitech G9x, Wolfking Warrior keyboard, Samsung 2233SW, CM Elite 33x, XBOX 360 Controller for Windows
iPOD Nanoch
Reply to hellraiser06
Topower is a tier 5 unit on this list of psu's:
http://www.eggxpert.com/forums/thread/323050.aspx
As games enter 3d mode, they draw more power. I suspect that your psu is not that capable. See if you can test your system with a quality psu.
Reply to geofelt
I've never heard of that brand before, personally I'd check the PSU before blaming the GPU. the GTS needs 600w recomended and a 12v @24a if I'm not mistaken, it's quite probable that the PSU can't output that and it's causing the computer to crash when underload.
------------------------------ Core i7 920 @ 3.9ghz
2x 9800GTX+ BFG OC
3GB OCZ 1600mhz RAM
Coolermaster HAF
Reply to Rain1406
Thanks Guys for the help, im going try to get a better PSU,and see if that works, thanks again for the help will post my PC specs. later
Reply to LuisFernando
There are 1099 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
  • 01:00 xpax won the Freshman badge
  • 01:00 Mizoguchi won the Freshman badge
