Fujitsu power button bezel cable
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Fujitsu power button bezel cable
Please help, I have a Fujitsu N6010 -- and the ribbon cable from the Power Button bezel came loose while I was changing out the screen. Here's my question -- the cable side that connects to the laptop doesn't have a connector on the end. It's just ribbon - I found a replacement bezel with cable on eBay and ordered it; and when I received it, it was in the same condition. How do I reconnect it? Is the one I purchased broke as well, or is there a way to connect it that I just don't understand?
Sponsored Links
If it's just the ribbon, then it probably is a zero insertion force connection.
Try google to see if you can find a picture of this connector.
------------------------------ Never argue with a fool, people might not know the difference
Reply to dunklegend
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Fujitsu power button bezel cable
There are 1295 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
