Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > [Solved] Front Panel HD Audio Cable Too Short
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - [Solved] Front Panel HD Audio Cable Too Short
Best answer from JohnnyLucky.
The front panel HD audio cable on my CM Storm Scout case just barely will reach the header block on my ASRock X58 Extreme mobo. But it's in the way of the expansion sockets. It's a 9-pin plug, five pins on each side with one pin blanked out. I tried NewEgg and called a local computer store. Anybody know where I can get an extension cable?
Mikey
Here you go:
http://www.performance-pcs.com/cat [...] s_id=21039
OOPS! That cable is for headphone and microphone only.
Here's the 10-pin version:
http://www.performance-pcs.com/cat [...] s_id=22079
It has 10 cables. You can remove the appropriate cable. Here's a link with detailed instructions and photos showing how to remove remove and insert a cable:
http://www.frontx.com/head_con.html
EDIT - NOTE - I used that 10 pin extension cable 4 or 5 years ago. It's not the greatest extension cable inthe world. Follow the cables from one connector to the connector at the other end to make sure the cables are going to the right connector pin. Also, that 10 pin cable is not as well shielded as the one in the first link. Route the cable behind the motherboard tray as much as possible.
Sponsored Links
Best answer
Here you go:
Message edited by JohnnyLucky on 09-16-2009 at 01:50:13 AM
Reply to JohnnyLucky
Thanks JohnnyLucky. There's no pin in one position on the mobo anyway so it won't hurt if the pins and wire are there in the cable.
Mikey
Message edited by Mikey_81 on 09-16-2009 at 05:22:01 PM
Reply to Mikey_81
True. You just need to make sure that you maintain the polarity of the connectors.
Reply to jsc
There are 1256 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
