Tom's Hardware > Forum > CPU & Components > CPUs > Do i7's have power saver if idle?
Forum CPU & Components : CPUs - Do i7's have power saver if idle?
I've read some comments that. Example my i7 920 is idle. The processor will only use 1core @ 1.60ghz. Is this true?
Sponsored Links
No, all cores will remain active, but the "Intel Speedstep" function (if it's not disabled in the BIOS) will throttle clockspeeds and core voltages back when idle, effectively reducing power consumption, but even without speedstep any CPU consumes less power when idle.
------------------------------ CPU: Intel Core i7 920 @3.2Ghz, MOBO: Asus P6T SE, RAM: 3x 2gb OCZ Platinum OCZ3P1600LV6GK, GPU: Sapphire HD 5870, PSU: Corsair HX520W, HDD: Seagate ST31000528AS 1Tb 32mb, COOLER: Scythe Mugen (S775 version), CASE: Coolermaster CM690
Reply to Gulli
thanks for the reply..
the i7 920 requires 130w. so does it mean.. it idles at 130w? or it will reduce?
Reply to ak47carbine
It will consume much less at idle.
It consumes 130W at full load at stock speed, full load means all cores 100% active, that won't happen with daily use or even gaming.
Message edited by Gulli on 09-16-2009 at 12:24:06 AM
Reply to Gulli
The i7 has the capability to fully shut down idle cores, not just throttle them back. This is part of the reason the new i5 and 1156 i7 CPUs have such low idle power.
------------------------------ Asus P6T deluxe
i7 965 @ 4.2GHz (200*21), 1.384V
12GB Corsair Dominator DDR3-1600 CAS 7
Reply to cjl
Yes, but I don't think the 920 has that feature.
Reply to Gulli
Ok, now it is clear to me. Thank you so much guys.
Every i7 has that feature. The socket 1366 models still take a lot of power at idle (comparable to older core 2 quads) because the northbridge and all the RAM takes a decent amount of power, but the newer ones really show the benefit.
Message edited by cjl on 09-16-2009 at 03:29:08 AM
Reply to cjl
All cpu's and gpu's throttle down at idle.
Reply to zipzoomflyhigh
ak47carbine wrote :
in your instinct :D
so how many watts at idle??
Maybe 30W to 50W, but that's just my gut feeling, could just as well be 15W, but when looking for a PSU you always have to keep a 100% loaded CPU in mind.
Reply to Gulli
30W to 50W sounds about right.
------------------------------ http://i62.photobucket.com/albums/h82/TXSuperFly03/478x88copy.png
Reply to yomamafor1
At idle my cpu is only doing 10 watts at .918v and it's still set at stock, were do you get 30-50 watts at idle for a I7-920?
Reply to kg4icg
ak47carbine wrote :
in your instinct :D
CPUID shows my Core i7 920 at a little under 50W at idle.
Reply to sminlal
Just curious. How do you get that figure?
Reply to yomamafor1
I'd bet the CPU alone uses quite a bit less than that. With the northbridge and memory, that could be about right though.
Reply to cjl
there is a utility for gigabyte boards called dynamic energy saver that shows wattage used by the cpu. it woks quite well.
Reply to kg4icg
But is it correct? I've yet to find a power utility like that that I would trust.
Reply to cjl
The Intel datasheet shows that the CPU itself consumes 12W of power in the C6 state - that's the lowest possible power level before entering sleep state with the processor clocks quiesced and the register contents flushed out to cache. So if you consider that to be "idle" then yeah, that's the official power consumption of the chip.
What I treat as "idle" is when the CPU is active and responding to user input, but with the cores at essentially zero percent utilization - and under that definition mine is consuming a tad less than 50W.
Message quoted 1 times
Message edited by sminlal on 09-16-2009 at 09:55:42 PM
Reply to sminlal
I agree, and it also depends on the vcore that's being applied to the chip: "auto" settings doesn't necessarily mean "lowest vcore possible".
Reply to Gulli
I see, i haven't overclock my i7 920 it is still @
2.66ghz.. So what is the suggested vcore? Thank you.
Well thats a good grief.. I thought the cpu idle power reaches 100w or something.. now the gpu, im worried about,.
Depends, I've got 1.21875V for 3.2ghz, but every chip is different.
Reply to Gulli
Every chip is different - if you don't plan on overclocking, leave it on auto though. If you do plan to overclock, the recommended maximum is either 1.375V or so, or 80C full load (some people will say a bit lower than this). You can overclock as far as you want until you hit one of these limits. In many cases with the i7, you'll hit the thermal limit first though.
Message edited by cjl on 09-16-2009 at 11:46:04 PM
Reply to cjl
ok thank you so much guyz.. i really appreciate all your help.. one last question..up to now i havent applied some thermal paste in my cpu.. but the stock hsf had some pre applied thermal paste. is it ok?? im not planning to overclock my i7 920 ..
It should be fine, yes.
Reply to cjl
The problem is that by using software that is polling for power consumption data you are possibly preventing some cores from entering the deeper C-states. Kind of the same reason (among many others) why you can't measure idle temperatures that accurately either, because you're polling every core in that case.
Reply to randomizer
Here is a wattage measurement from Everest for the cpu at idle
http://i445.photobucket.com/albums/qq175/kg4icg/th_temps.png
and by the way I was gpu folding at the time I took this screen shot
Message edited by kg4icg on 09-23-2009 at 07:12:10 PM
Reply to kg4icg
There are 1125 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
