Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Using a 350watt gpu on a 300watt power supply?
Forum Graphic & Displays : Graphics Cards - Using a 350watt gpu on a 300watt power supply?
I don't know the power rating of my power supply but I think it's a 300watt
My gpu needs a 350watt power supply
I am running it on that 300watt power supply
I want to know that is it possible that 350watt gpu can run on a 300watt power supply and what are the bad consequences that can happen?
Sponsored Links
is plainly a bad idea
it might manage if lucky to struggle along for a short time - sounds like you are already doing this !?
though depending on which GPU you have, they no doubt spec'd it to include the system as well as one card
It will stress the PSU beyond what it was designed for, and will cause system instability when it fails to keep all voltages within designated ranges when it is over stressed... leading to crashes etc
or even cause the PSU to blow which could take out other PC components as it goes down :ouch:
especially possible on no name cheapo brands.
I highly recomend going with a brand that has a good reputation - am sure you are about to get a host of recomendations :D
Plan for you future - if you want SLI / XFire later etc
and get one that should easily cover your system. A Quality 5 - 600 watt supply should be plenty for single GPU systems
for Example I run:
Q6600 @ 3 - 3.6GHz
8800GT
6 HDD's
X-Fi Gamer SoundBlaster
Seasonic 500w PSU
Fan controller, 5 x 120 mil fans and usual bits and bobs....
never goes over 265 watts even under load - have my system on a load monitor all the time for curiosity
Upgrade that PSU sooner rather than later ~_^
Reply to Pailin
- 0 +
palin what the hell are you talking about? you have no clue and should keep your idiot opinions to yourself and save the rest of us from your dribble! a 650w PSU for a vidoe card you dont even know! Do us all a favor and delete your Tom's account.
Reply to ct1615
- 0 +
pay no attention to that fool palin, he knows nothing about power supplies or video cards
you need to help us by answering two questions
1. what power supply do you have, make and model if you know it? Some PSU list peak power while others list continuous power (two separate things). Your power supply may actually peak at 350w or over but without make and model we cant tell. The most important detail is the amps on your 12v rail. That information will helps us out more then just the 300w.
2. What video card are you running? Some manufactures may ask for a 350w as a worst case scenario but the card itself may draw few amps and watts and be able to run on a 300w PSU.
3. and if you do need a new PSU, you certainly need no where near 650w for a 350w card.
Reply to ct1615
- -1 +
To be so vehement without the ability to read between the lines is a little depressing...
sorry I took it for granted that livegamer1 might be intelligent, as you clearly are not :pfff:
let me explain what I wrote so it is a "little" easier to understand for you...
"it might manage if lucky to struggle along for a short time - sounds like you are already doing this !?
though depending on which GPU you have (clearly a question), they no doubt spec'd it to include the system as well as one card "
"and get one that should easily cover your system. A Quality 5 - 600 watt supply should be plenty for single GPU systems "
(pointed out that it should be more than probably needed - as people seem overly keen on Oversized PSU's, which are Totally unnecessary)
and then to make that Even clearer:
I point out my system never even comes close to what a 500watt PSU provides even loaded with HDD's and OC'd a lot !!!
All hinting at the possibility that depending on some of his answers, what he has already "might" even be ok, if his is a quality PSU...
Learn to read mate, before launching into Full Flame mode :non:
Reply to Pailin
- 0 +
I'm no mate of the village idiot! don't try to backtrack, your a complete fool as your answer clearly proves Leave the thread and rid us of your stupidity! You failed to ask him a single question! You want to be depressed then go sit in your mother's basement and think about your life but don't ever post to me again! Or I will embarrass you again and point out your stupidity once more!
Reply to ct1615
- 1 +
@ Livegamer1: Is this, by any chance, a Dell we're talking about here? If so do n't be too worried, their power supplies are famously underrated.
If it's not a dell: Exactly which PSU is it? Exactly which GPU is it? Most companies overstate the power needs of thair GPUs' to counter for the large number of poor quality power supplies out there.
------------------------------ Peace cannot be kept by force, it can only be achieved by understanding: Eienstien
Reply to coozie7
- 1 +
^ Can we be peaceful!
OP depends, can you give us the spec of your psu? Companies overate how much power they need. For instance my 2 gtx260 sli need about 650w+ but im running it on a high quality 500w. So i need the spec of your psu and what graphic card your looking at.
Reply to invisik
- -1 +
Other good people here are capable of reading...
You suggest I am backtracking... ---further proof that even my explaining what I wrote was a little beyond your comprehension lol
Clearly I am "opening a dialogue" in the way I wrote what I did.... inviting him gently to provide more info as he felt like
not everyone has to Directly ask in extremely obvious terms for what they want :heink:
suggesting a possible 500 - 600 watt supply MAX saying it was More than plenty
and Further emphasising this by pointing out my system: "never goes over 265 watts even under load"
Quite clearly indicating that depending on his GPU choice with a good PSU he "might" be ok as is.
All the points in my original post openly invite further information to be provided, I have no need to backtrack on anything.
Go back to school fool... you seem to be a little deficient in the brain department, and manners...
and let us get to the bottom of what his requirements are without more of your idiocy
Reply to Pailin
- 0 +
Sorry about all that
hopefully we can now get back on track :)
Reply to Pailin
- 0 +
I told you do not post at me again. Now to embarrass you once more since you obviously lack any intelligence!
You failed to ask a single question form the OP! fail #1
You told him to get a 650w PSU for a 350w card! fail #2
Not only are you a complete idiot but a total failure! Post to me again and I will continue to embarrass you!
Message quoted 1 times
Message edited by ct1615 on 07-03-2009 at 05:25:39 PM
Reply to ct1615
- 0 +
more then likely it is and I'm guessing the card in question is the Nvidia 9500GT. Nvidia asks for 18amps on the 12v for the 9500GT, probably a bit more then what is needed but the Dell 300w PSU does deliver it.
Reply to ct1615
epic lawlzers...
btw, I'm running an overclocked 4650 (stated power requirements of 400watts) on a 305 watt Dell PSU. :p
------------------------------ i7 920, E5300
GTX260, HD4870, HD4830
Reply to Bluescreendeath
- 0 +
Bluescreendeath wrote :
epic lawlzers...
I ran a 9600GT and 9800GT on that same PSU. It's like the little engine that could. ;)
* edit, I did toss in a 500w PC P&C PSU for when I upgraded the CPU
Message edited by ct1615 on 07-03-2009 at 05:39:11 PM
Reply to ct1615
lol, nice :D
I really do wonder what the actual wattage of that Dell PSU is. Is it equivalent of a 400watt PSU maybe?
- -1 +
hmm, no helping some sadly...
#1 I clearly explained how and where I asked the questions etc which any sensible person could see, which you failed to understand both 1st time around and even after I took time out to explain it...
Here one of my more obvious questions for the 3rd time : "though depending on which GPU you have..." = a question, gently prompted
he gave very little info in his post, suggesting in doing so that probably his PSU was a no brand one - in which case should be replaced soonest.
#2 Nowhere do I mention a 650watt PSU...
I mentioned a Generous 5-600watt PSU (5-600 in layman’s terms means 500 to 600 Not 650... :pfff: )
and people have a tendency to like to get a somewhat larger than necessary PSU, so I suggested the biggest I hoped he would get. Then Very Clearly pointed out that one that big was Very likely unnecessary. Followed by saying than he would probably get a slew of suggestions of models to choose from - many of which suggestions I imagine would be about 450 - 500watt + ---> about what I suggested (bearing in mind how I Extremely clearly pointed out how my 500watt Seasonic was overkill)
Hopefully you can manage to grasp those simple facts the 3rd time around, else any further response will probably be quite futile :sarcastic:
I thought what I originally said was pretty clear and to the point given the limited initial information available...
if nitpicking was what we are about then your:
"3. and if you do need a new PSU, you certainly need no where near 650w for a 350w card."
if his card alone was 350 watt as you suggest - then damn, but you'd want a new PSU pretty quick
oop, and here is ct1615 pointing out a recommendation of just what I suggested in my 1st post: "* edit, I did toss in a 500w PC P&C PSU for when I upgraded the CPU "
approx a 500 watter ! He Finally gets there :)
ct1615 you REALLY should learn to read and Comprehend what people are saying b4 launching into Flaming them :(
On topic:
[url=http://www.tomshardware.co.uk/forum/page-266755_15_0.html]
This thread has a new helpful suggestions[/url]
They talk of a PSU in the region of a 500 - 650 watt PSU (650 a little excessive maybe pending a little more info you live's setup)
of such Brand names as:
Antec
Corsair
PC Power & Cooling
Seasonic
Well, on that note, good luck building your rig up to the beast it should be and I will leave you to the helpful advice of some of us here who are I am sure a little more prone to intelligent responses than unfounded, confused flaming ^^
Reply to Pailin
- 0 +
pailin, the only flamer is you
everyone else here has been helpful to the OP and asked questions but you!
you are a complete and total idiot who thinks by attacking me you will prove you know what you are talking about. You won't, you are a fool, and you have simply been beaten by me with facts of lack of intelligence with each and every post. For the last time, if you continue to post at me you will continue to lose and be embarrassed by your lack of intelligence!
Reply to ct1615
- -1 +
i smell a troll, you are just insulting him for no good reason.... so TITS OR GTFO
anyhoo
on topic
Like coozie7 said, the recommended psus are greatly overestimated, if a manuf sais you'll need a 450W psu to run a card that actually draws 50W they are just afraid of poor quality psus and stupid ppl sueing them...
Take a look here for some hard facts on gpu power usage: http://archive.atomicmpc.com.au/fo [...] t=9354&p=0
Reply to Kari
- 0 +
anyhoo
on topic
if you had taken the time to actually read the thread you would see coozie, blue, invisik, all agreed with me that more information was needed on the PSU before any decision can be made. One person suggested purchasing a 650w PSU right off the bat. So perhaps you should GTFO!
Reply to ct1615
- 0 +
lol, nice :D
305w is its continuous power, it peaks above 305w. It has 18 amps on the 12v which is about what you find on an average 375-400w unit.
Reply to ct1615
There are 901 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
