Archived from groups: comp.sys.laptops (More info?)
I have a Compaq Presario 700US notebook that wont even POST when plugged
into AC or battery - no sounds, no lights, nothing. I noticed that when I
plug powersupply into the laptop the light on the powersupply turns off (the
light on the powersupply does come on fine when it isn't plugged into the
laptop). I have checked the voltage coming in from the battery and the
powersupply and that doesnt appear to be the problem. I have taking the
notebook apart and other then verifying the power coming in, there isnt much
else I can test.
Could this be a motherboard gone bad? Any suggestions?
This suggests an overcurrent condition, probably a dead short in the
laptop, which is forcing the brick into shutdown. You can try to
isolate this step by step by lifting components off the board to
locate the short.
> locate the short.
Have you tried connecting the power supply to the laptop while the
battery is removed ? If you already have, sorry for asking the obvious
but if you have not, chances are the battery is causing the problem.
Well, I hope, since the alternative is indeed the motherboard and on a
laptop, there is not much you can remove to isolate the problem ...
A dead short battery will not normally shutdown the external brick.
Monitoring for a shorted battery is a normal function of the charge
controller.
