Solved
Liquid Cool 3 6970's Help with parts
  • Water Cooling
  • Computers
  • PowerColor
  • Overclocking
May 27, 2011 6:25:35 PM
Ok so i am going to get 3 PowerColor 6970's so i need to watercool them. I have built a lot of computers in the past, but never watercooled anything. could i please get some help. Thanks
More about : liquid cool 6970 parts
a b K Overclocking
May 27, 2011 7:53:42 PM
some questions for you;
are this reference cards,what's the case and the budget ?
m
l
a b K Overclocking
May 27, 2011 8:11:16 PM
if you getting the card/waterblock combo ,all you need is good quad RAD ,pump,res,fittings,fans,and tubing.
I don't thing 200$ is enough but close
P.S. don't know much about the waterblock the card comes with,you can learn all the basics from the sticky on top of this forum
m
l
a c 337 K Overclocking
May 27, 2011 8:18:21 PM
Are you only watercooling the cards?
Pump + rads will run you close to at least $200.
m
l
May 31, 2011 4:36:36 PM
The cards come as a watercooled card, so i think i just need tubing a pump and rad? but im not sure what to get.
m
l
Best solution
May 31, 2011 5:54:53 PM
If so, then yes. You might consider a reservoir to make it easier to fill the loop, but not totally necessary as a T-line can easily fulfill this need.
MCP355 $65 http://www.sidewindercomputers.com/swiftechmcp355.html
DDC top/res $40 http://www.sidewindercomputers.com/bibpddcmiwat.html
XSPC RX360 $86 http://www.sidewindercomputers.com/xsrx3xrare2.html
Yate Loons (med) $18 (3x$6) http://www.sidewindercomputers.com/yalo12d1cafa1.html
$209 before shipping. You will also need to consider fittings...either 1/2"ID or 3/8"ID and tubing will need to be considered.
a b K Overclocking
May 31, 2011 7:34:26 PM
I just like to make a note..if you go the DDC + TOP route ,get Koolance PMP-400+COV-RP400 (or the mini rubix mention)
the warranty on swiftech pump will be waived as soon you open the pump
m
l
May 31, 2011 7:36:30 PM
^Good point. Yes, adding an aftermarket top would normally void the warranty unless you get a pump/top combo that was pre-installed.
Aren't there others like this as well?
m
l
a b K Overclocking
May 31, 2011 7:43:29 PM
if you mean other company..as far as i know Swifty is anal in pump/support department ,
Koolance looks like the real deal as far the pumps go
m
l
June 7, 2011 2:02:11 PM
Best answer selected by sleapeasy.
m
l
June 7, 2011 2:02:29 PM
Thanks for all the help, it was greatly appreciated.
m
l
June 7, 2011 2:04:51 PM
Good luck...let us know if you have any other questions...also feel free to post back with pics, results, etc.
m
l
