Hey gracious helpers! I have never built a computer before, and I wanted to build an audio production PC with a budget of $1000. Is there anything I should be wary of as a first time builder?
APPROXIMATE PURCHASE DATE: June 13 - 22 BUDGET RANGE: $1000
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: audio production (sonar, reason), I also want to be able to play left 4 dead and starcraft 2.
PARTS NOT REQUIRED: USB Mouse, keyboard, speakers, 19" screen, audio interface
PREFERRED WEBSITE(S) FOR PARTS: no preference. There is a Fry's Hardware about 15 minutes from where I will be for the next month though.
PARTS PREFERENCES: I would like to have 6 - 8 GB of memory with as much cpu as possible.
OVERCLOCKING: Yes (I've never done it, but I think I am capable of following a guide. Are these parts good for overclocking and getting my money's worth?) SLI OR CROSSFIRE: Maybe?? I don't know a lot about this.
Here are two builds I have looked at so far. Also, I am wondering about AM3 and DDR3?? Should I be getting an AM3 Phenom II with DDR3 compatible motherboard and DDR3 RAM instead?
Another question: Is getting this thing running as simple as putting all the parts together assuming nothing is broken? Also, what is the time commitment for a moderate overclocking?
Re: Another question: Is getting this thing running as simple as putting all the parts together assuming nothing is broken? Also, what is the time commitment for a moderate overclocking?
Putting it together is straight forward. Manuals included.
If using EasyTune6 (included on the drivers disc cd) or higher with a "new" gigabyte motherboard, the OC will take around 2 minutes, including the restart.
OC should be made with care. Read about the art, in Toms forum.
Happy days
I was checking this stuff over, and this motherboard has huge DPC latency issues which is a nogo for audio production. Is there a different motherboard I can swap in this build?
For that monitor, you could probably save money on a lower end graphics card. A 4670 would most likely be fine unless you plan on upgrading your monitor. You may want to get a i7 920 for audio work. I understand that it is really fast for audio encoding. I do not what you require in terms of cpu power for your line of work, but if it involves encoding, I would get an i7 and save on the gpu.
thanks greg. I got everything ordered. I substituted the power supply from the build above, the dvd burner, went for a slightly better motherboard (more ram slots), and a less powerful graphics card. I don't really play video games although I might have toy with SC2 when it comes out.
1 x ($259.99) MB GIGABYTE GA-EX58-UD4P 1366 X58 R - Retail
$259.99
1 x ($26.99) DVD BURNER SAMSUNG | SH-S223L % - OEM
$26.99
1 x ($279.99) CPU INTEL|CORE I7 920 2.66G 45N R - Retail
$279.99
2 x ($12.99) FLASH 4G|OCZ FLDRV OCZUSBDSL4G R - Retail
$25.98
1 x ($79.99) CASE CM|RC-690-KKN1-GP BK RT - Retail
$79.99
1 x ($14.99) ROSEWILL RC-6-HDMI-MM-BK-2 HDMI 6FT - Retail
$14.99
1 x ($4.89) CABLE NIPPON|USB-6-AB-BK R - Retail
$4.89
