Compatible memory required for : Model Name: M925 | Motherboard Model: M925 | Ma
Compatible memory required for : Model Name: M925 | Motherboard Model: M925 | Maximum Memory: 4 GB | Total Slots: 4 (Currently Memory in 2 Slots) | Memory Size: 256 MB,256 MB, | Memory Speeds: MHz, MHz, | Processor Speed: 1799 | Manufacturer: ECS
1 answer Last reply
More about compatible memory required model name m925 motherboard model m925
  1. There were several variants of M925; M925, M925G, M925L, M925U, M925LU, and a few others.
    I assume since you report four memory slots that it is one of those combo motherboards that features 2 x 168-pin SDR slots and 2 x 184-pin DDR slots. You cannot use 168-pin and 184-pin slots at the same time.
    The board will support:
    168-pin PC100 or PC133 unbuffered non-ECC SDRAM 3.3V up to 1GB total (512MB x 2)
    -OR-
    184-pin PC2100 or PC2700 unbuffered non-ECC DDR SDRAM 2.5V up to 1GB total (512MB x 2)
    Technically, the chipset can support up to 2GB (1GB x 2) but due to the age of this board and BIOS, I would recommend no more than 1GB (512MB x 2).
    For best compatibility, do not use any memory marketed or advertised as "high density".
Memory Compatibility Motherboards
