Tom's Hardware > Forum > CPU & Components > CPUs > CPU bus speed and multiplier
Forum CPU & Components : CPUs - CPU bus speed and multiplier
Hi everyone,
what is the difference between 200x15=3ghz and 133x23=3ghz cpu frequencies? of course regardless of what brand of cpu. which is better or faster?
Sponsored Links
Theoretically, 200x15 would be faster. In real life, however, for a given core speed, performance does not scale linearly.
Reply to jsc
Remember that the system bus speed also affects other components besides the CPU. So slower system bus = slower system overall.
Reply to Herr_Koos
True, but performance still does not scale linearly.
Reply to jsc
With modern bus speeds of 200mhz quad pumped and hypertransport buses though, the difference becomes pretty small, and in fact if you have to start lowering the timings on memory, PCI buses, etc. to make the system stable, your overclock by raising the bus speed may end up with less performance had you left everything alone and just raised the CPU muliplier. (if your CPU is unlocked, if it is not, you have no choice)
Is there a difference between 133 and 200 by virtue of bus vs mulitiplier. Maybe, maybe not! Only trial and error with each system and benchmarking can really reveal that! Depends on the rest of your hardware, and how well it reacts to the increased system bus!
From say 200 to 220 should you go by bus or by multiplier? See this is where it gets complicated. Raising bus speeds more at this point does not impart much speed increase at all to anything system wide, except the processor, and it might do more harm than good by causing instability with other components. It may be better to raise a multiplier on the CPU and leave the bus speed alone when you reach these bus speeds.
This is really sort of a left over trick from days gone by, when bus speeds were a lot lower. By raising the system bus from 33 to 66, or 100, or 133 etc. back then did impart huge, huge gains in overall system speed. Much more than just raising the multiplier on the CPU to achieve the same CPU clock speed.
Message edited by jitpublisher on 09-17-2009 at 03:39:42 PM
Reply to jitpublisher
In the case of AMD if you raise the base clock 20% (from 200MHz to 240MHz) that also increases the IMC/NB speed.
A twenty percent increase in the IMC/NB speed should result in a 6-8% increase in memory bandwidth and a 6-8% decrease in latency.
You could also adjust the IMC/NB with a multiplier --- but the adjustments would only be in increments of the base clock speed.
Reply to wisecracker
There are 1140 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
