I recently installed a new graphics card and almost everything was working. But then it automatically started the installation of some HD audio blabla, I can't remember the name now, but I followed the instructions... apparently not very clever of me. But now I can't get back the sound eventhough I removed the new audio driver, the computer just doesn't recognize my old speakers anymore. I have even connected another pair, but same problem.
Can you guys help me here? I would hate to completely restore my system... AGAIN!
Be nice to know what card and brand when posting....Install an ATi card did we ? You can try going into the control panel and into "sound" and select what you want it to point to.....
OR
If it is an ATI card, go in and uninstall all ATI stuff and reboot. When you reboot don't let the machine install the software automatically. Open up your drivers ( downloaded drivers from manufacturers site) and select advanced when it prompts you. It will give you an option somewhere that wants to know if you want to install "sound drivers" or something similar..... say NO. Just install the graphics driver.
you have to go into the control panel and uninstall all the ATI stuff. And the ATI codecs too if they're there or don't unistall with the above.
Then, when the machine reboots, don't let windows find the driver, install the one you downloaded from ATI/AMD's site...... Do the advanced install and don't select to install the sound driver.
You can also go into the devise manager and delete or uninstall the ATI sound crap. START/right click MY COMPUTER/.... devise manager.
swifty_morgan@ I removed all the drivers, as I said, as well as the control panel, so it's only normal that it isn't there I could easily install it again and see if it gives me the option to say no, this won't take long.
The way I saw your problem is: when you intsall a new video card at the same time some codec or/and audio driver was install.
Like morgan said remove everything from the control panel. you've done that
Reboot you've done that too
Re-install your audio driver , from the dvd coming with your motherboard.
reboot
your problem should be solve.
------------------------------Life is good ...most of the time
Reply to jive
Hmmm, thanks, but I'm yet again puzzled. I restored my system completely... back to normal! Then I installed the new graphics card and right away the sound was gone. So it didn't have anything to do with the new sound driver... I think.
I will see if I can find an audio driver, but I really have no idea where... you know. they try to make it as easy for you as possible so they don't include anything in the package when you buy the computer. Doesn't make sense. CPU-Z gives me this:
Looking like crazy... what good is a graphics card without any sound
Maybe you posted this info and Im just glazing right over it, but this is a new ATI card right? All the new ATI cards have onboard sound solutions to transmit HD audio over the HDMI cable but if your not using the HDMI cable to transmit audio then it will not work. You just need to go into your Audio properties and disable the sound on the ATI card. In Win7(and I think Vista too) you just right click the speaker icon in the bottom right and choose playback devices. Then right click the ATI solution and disable. My computer is across the room from my entertainment center and I have 30+ft audio and video cables to hook them to the TV and receiver. This is how I change my audio output from my PC speakers to the digital output I use to connect my receiver.
