Tom's Hardware > Forum > Homebuilt Systems > New System Build > [NEW HTPC SYSTEM BUILD] need some help with internal parts
Forum Homebuilt Systems : New System Build - [NEW HTPC SYSTEM BUILD] need some help with internal parts
Well, I ordered all my parts for my first ever build, looks like this...
Case -- Thermaltake DH101
Motherboard -- GIGABYTE 9400 HDMI Micro ATX Intel
CPU -- Intel Pentium E5200
Memory -- G.SKILL 4GB (2 x 2GB) Probably could have gone W/ 2GB
Power Supply -- ENERMAX 425W ATX12V
TV Turner -- Hauppauge WinTV-HVR-2250 Media Center Kit Dual TV Tuner
CPU Cooler -- Scythe Ninja Mini
Sound Card -- HT | OMEGA CLARO Plus+
Burner -- LG Black Blu-ray/HD DVD-ROM & 16X DVD±R DVD Burner
Hard Drive -- Western Digital Caviar Green 1.0TB and Western Digital Caviar Black 1.0TB for storage purposes, Western Digital Caviar Black 500MB for OS, and other programs/storage.
OS -- Microsoft Windows Vista Home Premium SP1 32-bit or #7 --Still up in the air--
Wireless -- D-Link DIR-625 and Rosewill RNX-EasyN1
Keyboard -- ADESSO WKB-4100UB Black USB 2.4 GHz RF Wireless SlimTouch Ergo Touchpad Keyboard & just bought a Harmony One
This is my first build and I am mechanically inclined, just not to knowledgeable when it comes to this. I've printed out the instructions on how to put everything together, and I don't think I am going to have much of a problem. My question is, do I need any other parts to hook everything up, ie wires/cables.etc.???, or does everything I need come with all this stuff. If there are parts that I need please explain, so I can get a better grasp on it. Thanks
Sponsored Links
That looks like an excellent HTPC build. Your list looks complete (assuming you have a TV to hook it up to).
You might need some SATA cables since your motherboard comes with two and it looks like you'll need four total. If you bought the BD drive retail then it will come with a cable though.
How are you planning on hooking everything up? HDMI, DVI? Optical sound? You may need cables for all of that too.
Reply to rwpritchett
Externally I am all set;) From sound card, to my new Emotiva amp, then out to my speakers. HDMI to the Plasma.
SATA cables for all three drives and the burner, right? Bought everything from New Egg, so i guess I'm just lacking one SATA cable....??
Reply to upstatesledder
If the hard drives are OEM, they won't have cables. You can pick up SATA cables from any box store.
You may also want to add some software to your list. If you plan on ripping blu-rays, slysofts AnyDVD is a must have. You also may need blu-ray software depending on what comes with your LG drive. Some blu-ray drives come with a version of PowerDVD that cripples the sound to 2-channel stereo only.
There are 1153 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
